Results 1 to 10 of 11
Thread: Wheel Bearings
    Default Wheel Bearings
    Hi guys, just a quick question, dads Vectra had a droaning noise coming from the O/S/F wheel area, hence we took it to arnold clark vauxhall - as I work for 1 of their other branches and get trade price parts/labour - anyway mechanic went a road test with my dad and knew right away it was the wheel bearings needing sorted (the cars done 101,000 miles as a taxi) so we arrange to have them replaced.
    get a phone call later on that day from reception staff to tell us that wheel bearings arent available separately, they come complete as part of the whole hub, hence we'd need to replace the whole hub to sort out the gubbed wheel bearings, its a 54 plate 2.0 DTI diesel
    just wondered if vauxhall were at it and telling us porkies to exert more cash from us as I personally have never heard of anyone having to buy a new hub just to rectify broken/worn wheel bearings
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    As far as i am aware mate, it true. You have to get a whole hub just to change the wheel bearing's!
    its a terrible design in that case then, but no doubt 1 vaux conjured up with the idea of making as much as possible out of a common fault thats usually cheap.
    I nearly choked when dad said it was costing 200quid inc vat with my staff discount applied for wheel bearings.
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    just had my 04 si done its true all complete with hub
    Nov 2005
    scotland
    the wheel bearing unit is bolted onto the hub carrier by three bolts and on some models dependant on spec also has the ABS speed sensor built in.
    They are about £134 pounds from Vauxhall but any good motor factors will sell an SKF wheel bearing which is the exact same part just in a different box for about half that.
    James
    scotland
    http://cgi.ebay.co.uk/Vauxhall-Vectr...aring-with-ABS
    its an easier job to do rather than messing around with inner/outer races and bearings !
    Aug 2007
    High wycombe
    Default AA site that tells about wheel bearing recalls
    Hi, I have a 2.0 diesel estate and there is droning from back end. Mind you it has now done 119k and it is a 53 reg 04 car and it has been droning for 10k miles.
    I did some searching and there is a recall for cars between certain VIN numbers - so you may want to look at that site - i think i searched for 'vectra recalls' and you may get the work done free of charge.
    market harborough
    Quote Originally Posted by mainand View Post
    Any idea what the web site address and how long it was you saw this
    Regular Member justyb's Avatar
    wigan
    yeap its true a new hub
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Quote Originally Posted by scottietlr View Post
    You can look on the AA web site I believe or honest John
  1. Wheel Bearings?
    By PedroMV6 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 16:56
  2. wheel bearings ????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 20:52
  3. Wheel bearings
    By Days of thunder in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2008, 08:26
  4. Wheel bearings
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 8th April 2008, 10:08
  5. Wheel bearings - again
    By kinger in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2006, 20:32
