Thread: Oil drain plug in 1.8 Vectra (51 plate)
    Nov 2007
    Aberdeen
    Question Oil drain plug in 1.8 Vectra (51 plate)
    So is that 2P size plastic screw with what looks like a Torx head the oil drain plug?
    What size thingimy do I need?
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Think it's a t40 - best get a couple cause these can be sods to get out and the bits can snap or round the plug
    Nov 2007
    Aberdeen
    Oh great - plastic plugs - what genius thought that one up!
    And where oh where did they hide the fuel filter?
    11 Post(s)
    Quote Originally Posted by IamtheStig View Post
    Think it's a t40
    Correct size is a T45 bit.
    Nov 2005
    Somewhere in time
    Close then -haven't needed to do this since my 1.8 3 years ago
    Nov 2007
    Aberdeen
    I have another problem with this car - other than the loose nut behind the steering wheel (it's OK my wife doesn't read this kind of site)
    The engine makes a rattling sound on accellerating - worse when in gear, but does it out of gear as well - not so much a throaty roar as a tickly cough. I checked this with the dealership and was told that all Vectras made that noise - it has got worse recently.
    Any idea what it is?
    north east
    fuel filter is underneath car just in front of petrol tank
    nightmare to get off
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by brucea View Post
    My 1.8 (53 plate) has a metal sump plug with an o-ring seal, not plastic.
    The plug can be tight though as mentioned.
    anywhere
    to help with the removal of the sump plug make sure the engine is hot, it cos its all aluminium, even if you crack it off when hot then let it cool to remove the oil. make sure you use fully synthetic 5w30 oil.
    the dealer fobbing you off.... try another dealer, or drop it into a local independant for their opinion..then take the findings back to VX..
  1. Oil Drain Plug Vectra C 2l Dti
    By dc6839 in forum Engine & Drivetrain
    Last Post: 6th July 2011, 08:17
  2. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  3. Magnetic Oil Drain Plug
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2009, 14:36
  4. oil drain plug ?
    By dmoffat in forum Engine & Drivetrain
    Last Post: 17th June 2008, 10:27
  5. Sump drain plug?
    By Paulmac07 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2006, 21:43
vectra plug at front of engine on 51 plate
