Results 1 to 10 of 11
Thread: Dodgy Light Sensor...
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Default Dodgy Light Sensor...
    I've noticed that my light sensor warning comes on and goes off. Anyone had this?
    Light sensor warning?
    As in lamp warning? Double check the bulb and make sure its the correct one you check if its a brake light as the car will use another lamp in its place - clever safety feature
    As in lamp warning?
    Ah yeah, could be that.
    Or is it for the auto lights?
    That's what i thought at first, but his profile says a 2002 model so I ruled that out.
    Mar 2007
    NI
    Sorry Guy's had to leave to do some work.... yeah its the lamp warning. Had it few months ago when the front N/S main beam went. Only comes on during a few seconds when I'm traveling downhill going at about 50-60 mph. Not too sure will check the lights tonight.
    Jul 2006
    Mexico
    I had several bulb warnings but the bulb was ok, at the end apparently the bulb was kind of loose in it`s socket....try to tight it and check the electrical connection for good contact HTH
    Mar 2007
    NI
    I think your right rob. It is very inconsitant. I'll have a good check around. Also my rear driver's side light unit has a crack in it so the contact maybe dodgy there.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Do you have front fog lights?
    My harness connector in the front bumper was all corroded and some pins became non existent, hence light not working and warning indicators coming on all the time. Started on very intermitantly but became permanant.
  1. abs light/sensor
    By stret in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2012, 00:37
  2. Bizarre! Battery light and dodgy hill start
    By ScottyV6 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2011, 17:28
  3. What are the sypmtoms of a dodgy MAF Sensor
    By craigbarlow18 in forum Engine & Drivetrain
    Last Post: 18th September 2009, 18:10
  4. Dodgy Temp Sensor
    By abhinn in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2009, 10:22
  5. dodgy battery light!
    By monkeyhinger in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2008, 18:21
