Results 1 to 10 of 15
Thread: Will it fail an M.O.T ?
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Will it fail an M.O.T ?
    after getting the two rear tyres replaced at an asian garage called M+M tyres and exhausts in middlesbrough, they snapped one of the bolts so it is stuck into the disc , they said they would remove it , but after i saw there total incompadence i thought id stay well clear ! any how will my moter fail its M.O.t as i only have four bolts instead of five in one of the rear wheels ? or will a new disc be required before the M.O.T thanks
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    If you take it to someone like quickfit they should be able to remove the bolt. This is slightly different but i had locking bolts that rounded off a few years ago & they drilled them out. It's possible to do it so you should'nt need to replace the disc as for the m.o.t not sure about that
    Feb 2006
    north east
    tried to drill it out myself , and made a right mess of it i even tried to use self extracting threads still no luck mate
    Jun 2007
    Wirral
    Quote Originally Posted by The Gas Man View Post
    Why mention they are Asian?
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    anybody with a welder and heat ..they will remove wheel weld a nut on to broken stud then heat them up and it should come out , it sometimes takes few atempts
    yep..you shouldn't need a new hub flange ( which on the vectra's means a new wheel bearing ).. either do as Rory suggests, or when you drill it, remove the core with a small drill ( 5mm) then go in with an 8mm..it'll either do 1 of 2 things..remove enough material to 'break' the rust seal on the threads and spin it in behind the disc.. or remove enough material to let you fold the remainder of the old bolt in on itself and push it out with a pin punch..
    when you said it has 'gone wrong'.. what have you done to it??
    and yes, if the MOT tester spots you have a wheelbolt missing, it's a failure
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    don't let him, or her, see it then. Cover it with something so to obscure it.
    Regular Member grumpano's Avatar
    North West
    Why not?
    The world is pc mad.
    spoons
    Guest
    Quote Originally Posted by neilrj View Post
    .....because they weren't American
    Its quite common in british 'domestic' culture to refer to a group of people by their ethnic origin. Its been going on for years.
    Some britains continue to refer to 'the irish', 'the scottish', 'the welsh' & 'the ozzies' as examples. They also get hacked off, but dont make a deal of it and we all live happily as they have given up trying to 'take over'
    Britains also de-individualise their close family as well... 'the Wife', 'the Mother-in-Law' etc etc...
    I have a lot of respect for Asians, especially their intelligence and business acumen. I've noticed that inner cities are now being dominated by Asians, turning cheap houses into valuable assetts, Asians are targetting the high paid intellectial jobs and cashing in on british wealth (Legal Sector, Healthcare, Hospitality) - Doctors, Solicitors, Lawers, Dentists, Corner Shops, Restraunts, Taxis, cash & carrys and are now spreading out to rural areas with their wealth.
    We could learn a hell of a lot from Asian culture. Education is the key and some british are too happy to sit on their ar$e and claim government handouts or just moan at how hard it all is....
    But hey... it'll all turn out for the good.
    morton
    had the same problem on a renault i had ! just drill a pilot hole as near to the middle of the left over stud ! the tap in a torx bit ! undo as normal ! it works a treat normally !!
  1. Mot Fail
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 12:16
  2. MOT fail, Co2
    By GCusdin in forum Troubleshooting
    Last Post: 24th September 2011, 10:06
  3. Fail MOT
    By rickyf1 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 18:21
  4. Fail :(
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 19:48
  5. HELP With M.O.T FAIL!
    By corderz in forum Troubleshooting
    Last Post: 25th May 2011, 09:23
