Thread: 2.2 dti 02 problems
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default 2.2 dti 02 problems
    This girls car, listed above, has a problem.
    everytime she accelerates or overtakes a car at speed, the spanner light comes on.
    it only comes on when she puts her foot down?
    many thanks if you can help.
    check the boost pressure sensor and the turbo boost hoses for splits in the lines, or oilsludge contamination in the boost sensor...or, for £40, get the fault codes read to see what they point to.. basic's first thou.. look for hose damage
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Check vac hoses, MAf sensor, boost sensor - if you can get the codes read then that will help.
    Edit: GSI3.2 beat me to it!
    Last edited by JuzzyD; 6th November 2007 at 23:15. Reason: lost 100cc somewhere...
    oi..3.1....
    wrong revision mate..
    Jun 2006
    Somewhere...
    Oops...
    Regular Member pscocoa's Avatar
    Oct 2007
    Sandhurst Berkshire
    There is a report in What Diesel Dec 2007 page 80 - a guy tried a few things to deal with ECU light coming on - he had a rolling road test and fault was identified as hole in the intercooler
    Jun 2006
    Somewhere...
    Quote Originally Posted by pscocoa View Post
    Could be a reason, but most likely its a split hose or faulty/dirty MAF or boost sensor on the DTi's - I would still look at those first.
    yep.. dti's have a list of common faults, and intercoolers are a rare failure..
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
