Thread: Engine coolant
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default Engine coolant
    can someone tell me how I replace the coolant please?
    the car is a 2.2dti 02
    many thanks if you can help
    best bet is to drop off the bottom radiator hose when the coolant is cold...you'll need to remove the undertray first, but then you'll have loads of access...drain the coolant to this level.. refit the hose and clip and then refill with red longlife coolant, refit the undertray..turn the heater selector to hot and bleed the system..recheck the level with the engine idling..
    Suffolk
    when you bleed it - does the air come out of the header tank?
    yep..thats the highest point, and where you set the level to...bleed it with the cap off..
    Suffolk
    can sum1 tell me if i need a special tool to get the clamp off the bottom hose?
    dont want to get under and find out then.
    Also how much fluid do i need and how much is it?
    many thanks
  1. loosing engine coolant
    By pud wayman in forum Engine & Drivetrain
    Last Post: 25th March 2012, 10:16
  2. loosing engine coolant
    Last Post: 13th March 2012, 09:14
  3. Engine coolant
    By Tank988 in forum Engine & Drivetrain
    Last Post: 11th July 2011, 23:49
  4. What engine coolant?
    Last Post: 31st May 2009, 23:45
  5. Engine Coolant?
    By jamesr in forum Engine & Drivetrain
    Last Post: 23rd February 2008, 22:07
