Thread: Help please with display fault ?
    Regular Member Teza's Avatar
    Feb 2006
    west midlands
    Default Help please with display fault ?
    Any one know what this is, its a box with water? wave of some sort. it comes up on the dash then goes it stays up for about 2 seconds when being driven.
    it's the radiator header tank level warning.. if the level is fine it's a dodgy switch.. if it's low top it up to the seam line on the tank.
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    i thought it was the air conditioning fluid.
    the AC uses gas/liquid phase...that symbol is deffo for the header tank on the rad..
    Mar 2007
    Grimsby, Lincs.
    its only cos i had one, and when i checked the book it said a/c and contact vx dealer.
    wine was a box with a little funnel in the top right corner and fluid on the inside. it came on startup and disappeared shortly after.
    if you check page 37 of your manual, it'll show you they symbol is for the coolant header tank..
    Feb 2006
    west midlands
    Thanks i will have a look
  1. Brakelight fault display
    By DARREN R in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2012, 23:15
  2. Display fault after new alternator
    By Chris-o in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2012, 23:58
  3. Centre Display Fault
    By firestorm in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2010, 21:16
  4. Display fault
    By Stefano in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2010, 15:22
  5. Mini LCD Fault Display is faulty (in RPM gauge)
    By RMillerin in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 22:04
