just had me cluch done and now the radios gone in safe mode,how do i get my code? its the cdr 2005 so i cant do it myself.do i just ring vx? what details do i need?
thanks gaz
thanks gaz
haven't you got the code for it on your car pass card or in the user manual?
If you don't have your car pass then its back to VX and £15 lighter they will send it to you
yep, they'll want TO SEE the V5 and a proof of ID to that address for you.. takes around 3-5 days..
it has gone up recently.....
Look in your servicing book for the details of where the car was first bought and give them a call. I did that recently because I never had a code card and the leasing company which owned it from new gave it to me over the phone.
Put Key In Ignition And Turn On
1. Turn Off Radio
2 Turn On Radio Leaving Your Finger On Asp Button Till You Here A Bleep And The Code Start Is Then Displayed
Button 1 Press To Start Your Code 1press =o 2presses =1 3presses =3 Ect
3. Second Number Code Use Button 2
4 .third Number Code Use Button 3
5 Fourth Number Use Button 4 Repeating Each Time As U Did With Button 1
Then Press Asp When Done Till You Hear A Bleep Then Code Is Inserted And Radio Will Scan If Correct.
Warning You Have 9 Tries Till You Block Your Radio
The Code Is On Your Car Card Or Book
Good Luck
Nigel
he's said his problem is he doesn't have the code card.....
