Thread: Oil pump failure????
    Nov 2007
    Rugby
    Default Oil pump failure????
    1.9 CTDI 2004 50000mls, just out of warranty! Just had a major engine repair, oil light came on, apparently oil pump drive gear was the fault. After 3 weeks, 540 pounds labour (no description) the bill came to a grand. Any know of this fault? A friend Former mechanic like myself has heard of this problem before, but nobody on this site appears to have experienced issue, unless I haven't read all the issues for Engine!
    Anybody had this fault please advise, I would like Vauxhall to contribute to this failure as I believe a car with just 50k should not suffer this type of major failure.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Get them to put towards this and dont let it rest either. You should get 90% towards it at the least. Has the car had full vx servicing? If it has you have a much better chance getting the full amount.
    Think you may get more answers if your thread title has more relevant wording, instead of a name - same with your other thread.
    Jul 2006
    Default Fred
    is this word association? Do i win? do i? do i?
    Nicking Ya Dinner.
    The only time I can remember this being an issue was with the old 8v units found in the Cavalier/Astra ranges of the 80's era, the strainer used to block up and stop the oil from being pumped around.
    Here, there and every where!
    Right, i've change it to something more appropriate, Putting a header like that just confuses people and they won't even bother looking at the thread.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Surely if the car has just come back from a major engine repair, then you have a case for it to be repaired FOC.
    Was the Oil pump touched in anyway at all during the Engine repair??
    Nov 2007
    Rugby
    Default Oili Pump Failure
    Quote Originally Posted by merikiito View Post
    Hi merkiito
    Sorry if this appears in wrong place on thread, as you might guess haven't done this before so didnt understand 'title'.
    I contacted Vauxhall, car was purchased as a Network Q car with less than 10k & under 12 months old. Contacted Vx and they only offered 20% discount on repair invoice. Was very dissappointed with response and repair due to 3 weeks to fix, no hire car, 540 pounds labour with no hours or desciption shown, oil pump gear shown as item replaced along with necessary gaskets for engine strip. No mention of crank grind or bearings, so any damage must have been minimal. This is 4th Vx owned, I feel let down.
    Nov 2007
    Rugby
    Default Oil Pump Failure
    Thanks for help. 1st time I've posted a thread on anybodys site, so as you can see didn't understand 'title'. I think I do now!
    It's ok m8, we all have to learn sometime. We just could not understand the title of the thread and it's meaning so i changed it for you.
  1. possible water pump failure
    By pud wayman in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2012, 14:50
  2. Power Steering pump failure
    By Partone in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2011, 21:16
  3. Diesel Pump Failure Rates
    By keithtinman in forum Diesel Engine related
    Last Post: 11th July 2008, 14:04
  4. Tuning box / Pump failure
    By Diesel Dude in forum Diesel Engine related
    Last Post: 9th March 2008, 14:34
  5. 1.9 CDTI 150 Fuel pump failure...help!
    By sri150 in forum Engine & Drivetrain
    Last Post: 13th November 2007, 15:19
