Thread: driveshaft seals
    scotland
    Thumbs down driveshaft seals
    took out my n/s driveshaft to replace leaking seal , all put back together then the f####r still leaked
    when I checked it all again I found the inner cv joint or more so the shaft which enters the g/box has some play , i.e. it can be moved up and down slightly.
    now ... is this supposed to be slackish or tight ?
    any mechanics out there that knows ? or will I just pull the rest of my hair out
    ps... the car still drives fine just the slight leak.
    slight movement is allowable.. but just how much have you got..any more than a millimetre at the joint is too much and the oilseal won't hold the gearbox oil back..which seal did you replace??.. is it the gearbox driveshaft seal?.. any wear ridge on the CV shaft?..
    scotland
    yeah was the n/s gearbox seal at shaft, no obvious sign of wear on the shaft , there is prob a few mm of play in it , might just have to get a hold of another and try that , or just the inner cv joint ,
    Regular Member Kyser143's Avatar
    Bradford
    Did you manage to sort this mate just i been told I have a leak on the o/s driveshaft seal..was it a long job..? mates going to do mine..just wondering how many crates to get him lol
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by Kyser143 View Post
    If for any chance you need a CV boot, I have a VX one in my cellar taking up space. Its yours if you want it.
    Bradford
    cheers mate..not sure if i need one ..been told by vx i have a leak on the o/s driveshaft seal...so got a new one for £7 but going to get a mate to fit it..i aint mechanically minded so no ideal if a cv is required..
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No worries.
  1. Vectra 1.8 2003 - driveshaft seals leaking
    By kicker in forum Engine & Drivetrain
    Last Post: 16th May 2011, 18:57
  2. driveshaft?
    By middy1966 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 16:23
  3. driveshaft
    By tditony in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 12:39
  4. Driveshaft for 2.2 Dti
    By damian s in forum Engine & Drivetrain
    Last Post: 20th February 2010, 18:35
gearbox oil seal for a 2007 vectra
opel vectra c leaking oil from drive shaft
vectra c 2.2 dti gearbox driveshaft oil seals
vauxhall vectra c 2.2dti driveshaft oil seal
zafira dti gearbox seal change
cv shaft oil seal to gearbox on vauxhall vectrac
vectra c driveshaft leak
corsa c drive shaft leak gearbox or engine oil
