Thread: swirl flaps
    Regular Member rob888's Avatar
    Oct 2007
    lincs
    Default swirl flaps
    ok engine management came on today so popped to Thurlby and they tech2'd it and it came up with swirl flap stuck, so thye have ordered new one/s and will be fitted on Wednesday.
    Said that its common for them to go on diesels but not petrols - mine 2.2 petrol.
    Thing is I forgot to ask what a swirl flap is...any ideas??
    If they mean Swirl Valve - it's a pneumatically guided swirl valves in the intake tract. Helping to bring the fuel-air mixture to a high swirl rate at low rpm. This leads to efficient combustion and high torque. At high rpm the swirl is reduced, improving performance.
    Most owners of the CDTi's have had dealings with this valve or will have IMO.
    Oct 2007
    lincs
    could that explain my rather poor fuel ecomnomy at the mo??
    Deffo matey. Does the car judder / hesitate at times as well?
    Oct 2007
    lincs
    no to be honest if the engine light hadnt come on I would not have known any different apart from rubbish economy, was hitting mid 30 now just hitting 30mpg...and with the stupid price of fuel not good!
    I do have the usual 'flat' spots on acceleration but i seem to think that is pretty common with the 2.2
    Regular Member Sundance's Avatar
    Scotland
    Done one before and If i remember correctly its a whole new inlet manifold, similar setup to the Z19DTH, except its a plastic manifold on the 2.2, is it a Z2.2YH or Z2.2SE, if its the YH then your flatspot could be down to your High pressure pump which is a fairly common fault.
    Oct 2007
    lincs
    yes its the whole inlet that they are replacing so i have the joy of a corsa loan car for the day, erm no idea about the Z thing...how can I find out??
    the car is an 07 2.2 direct sri if that helps?
    Scotland
    if its an 07 then its a YH, you sometimes get the EML coming on when the flatspot occurs but not always, they should be able to check the actual values of the fuel pressure on a road test at the time the flatspot occurs. Make sure you mention it when you take it back for repairs. Enjoy the corsa
    Oct 2007
    lincs
    i notice flatspots mainly when I am accelerating fastish thro the gears, almost feels like a bit of turbo lag lol...I wish!!
  1. hello to all and swirl flaps
    By hasbin0796 in forum Introduce yourself.
    Last Post: 11th March 2012, 16:31
  2. swirl flaps?
    By mickyblueyees in forum Engine & Drivetrain
    Last Post: 20th January 2011, 18:01
  3. Swirl flaps
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2009, 19:13
  4. Swirl Flaps Pt 2
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 18:43
  5. BMW Swirl Flaps
    By Diesel Dude in forum General Chat
    Last Post: 16th March 2008, 11:38
