Thread: fitting new bulbs
    Feb 2007
    airdrie
    Default fitting new bulbs
    Just bought some philips +80 bulbs and yes i know theres a how 2 about it but theres some conflicting posts in there so i was wondering if this was the best way
    remove the airbox and washer bottle, possibly the battery too to get proper access, rather than remove the headlights etc as described in the how 2
    cambs
    hi
    its a small gap to fit the bulbs but you will need to remove washer bottle neck(just pull out) and if you can just try and move the air intake pipe to one side(should just pull of) no need to remove headlights
    should only taake about 5mins
    for facelifts it actually 50/50 on if it's easier to remove the lamps or struggle around the airbox etc...it's all down to how small your hands are..
    [Ex]Admin Duncan's Avatar
    As your profile says an 06 model, I'm assuming you're talking about a facelift model here? If so, then it is a case of bumper loosened and lights off from what people have posted elsewhere. It is possible without taking the bumper off, but it's almost just as easy to loosen the bumper and do it that way.
  1. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  2. Problem Fitting HID Bulbs??
    By bonneyboy in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2010, 13:02
  3. Bulb Warning - Lose Fitting Bulbs?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2010, 11:02
  4. Fitting headlamp bulbs
    By Flyingkiwi in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2007, 01:44
  5. Face lift fitting silver indicator bulbs - Front
    By Andyuk911 in forum Electrical & ICE (including SatNav)
    Last Post: 24th July 2006, 14:39
