Thread: Will I need to disconnect my battery
    manchester
    Default Will I need to disconnect my battery
    I have just bought a K & N panel air filter for my vectra c 1.8 sri vvti and I have been advised by a work mate that I should disconnect the battery when fitting the filter...When I re-connect the battery the ECU will register that their is more air flowing through the filter and re- programme itself......Is this correct or can i leave the battery connected ????
    Here, there and every where!
    Some say yes, others don't bother m8. I fitted a K&N to both my Vectra and Signum and didn't bother. Fitted different varieties of tuning boxes too and never bothered then either
    Tyneside
    It will learn anyway you do it TBH so not much point IMO
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I derestricted my Airbox last week without disconnecting the battery and felt power delivery was a bit more sluggish afterwards.......then I disconnected and reconnected the battery and.......better than before I derestricted the Airbox. I was sceptical before, but not now.
    Nicking Ya Dinner.
    I think ppl think they need to disconnect for safety reasons, thats not required, I personally would have it off so the ECU clears and it learns on a fresh new page.
    Chelmsford
    Correct me if I'm wrong, but I don't believe the ECU clears when the battery is disconnected. I remember from my Vectra B days that a lot of people confused the modern ECUs with those in the old Cavaliers and Astras, which did reset the second power was lost.
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Quote Originally Posted by DNS View Post
    you do have to wait a good 20 - 30 minutes mate.
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    By diconnecting the battery for 20-30mins,when thebattery is reconnected, the ECU learns the new setting instantly, therefore giving you the maximum benefit of the Modification immediately. By not disconnecting the battery, the car will have to learn the new mod's qualities(Right word??) and therefore the process will take 50-100miles maybe, and you will not notice the difference as much as you will be driving the car while its learning, and the increase in performance will be more graduale, rather than immediate.
    If this makes sense to you, then you are a good man, coz its confusing me and i wrote it!!
    Nicking Ya Dinner.
    Quote Originally Posted by BigMan View Post
  1. Is it ok to disconnect EGR plug..?
    By Dippy-Vx-line Red in forum Diesel Engine related
    Last Post: 6th June 2012, 17:05
  2. CD30 battery disconnect
    By 19CDTi in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2012, 20:48
  3. Disconnect battery?
    By yoclick in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2009, 09:46
  4. Problem after battery disconnect
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2007, 20:02
  5. disconnect battery after remap?
    By trucker in forum Tuning
    Last Post: 17th September 2006, 08:49
