Results 1 to 10 of 14
Thread: Replacement shockers.......
    Regular Member scoobs's Avatar
    Leicestershire in the sticks!
    Default Replacement shockers.......
    As above I'm intending to replace both rear shockers on my 04 SRi 150 hatch. Was looking at LMF Bilstein B4's, would these be better than OE?
    Also is it really a simple job of two bolts each side or do I need spring compressors or other specialist kit?
    Many thanks........
    OE rear shockers are to be blunt, fappin terrible quality.. made down to a price....
    the bilsteins are a far better peice of kit altogether..they last much longer..
    the only tools you'll need are some torx sockets.. E18 and E20...no spring compressors etc at all..one bolt to remove at either end of the damper..
    Cheers Mark, don't mean to go on but as the SRi is lower than standard Vecs, will the B4's fit or do I need to order something different?
    just tell the guys at LMF your model and they'll supply accordingly..
    Cheers fella, you take it easy and treat yourself to another Lemsip!!!
    if i see another lemsip......
    i'm thinking of changing to the 'lager cure'....
    morton
    is yours a 150 cdti matey ? i have a set of eibachs in the garage , came off my petrol 2.2 ! did about 4k on them ! could let you have em at a good price if your interested ?
    Yep, 04 1.9 CDTi SRi 150............would the 2.2 shocks fit OK?
    Alcohol for purely medicinal purposes is fine............another occasion when drinks don't actually count!!
    Belfast
    Bilsteins are WAY better than Vauxhall's crap.
    My Astra ia handling better on standard springs with Billies than it did lowered 30mm all round on the standard shocks. Decent set of shocks on standard springs make a huge difference...
  1. kyb shockers
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 12:54
  2. shockers???
    By marshy200 in forum Handling & Braking
    Last Post: 6th January 2012, 21:50
  3. 3.2 gsi front shockers
    By TimTay in forum Suspension, Wheels & Brakes
    Last Post: 23rd March 2011, 17:56
  4. rr shockers
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 14:10
  5. Shockers
    By user999998 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 17:54
