Results 1 to 10 of 13
Thread: Alloys for latest Vectra, what size info
    Oct 2007
    Sector 7
    Default Alloys for latest Vectra, what size info
    Hi,
    Looking to upgrade to alloys and currently have steel rims fitted with 215 55 R16 93H tyres.
    What i want to do is get some tyre-less alloys and swap off these tyres to the new alloy rims but what alloys will fit my car?
    Had a look on fleebay and sellers are quoting figures eg. 5x 110, 7.5J etc..
    I've looked at the sticky that has a link to sizes and i see that i need the 5 stud 110PCD, offset between 35-45 but also shows a bore of 65, which no one mentions.
    Can anyone give me the correct rim sizes and all necessary figures, so that i can determine whether alloys are going to be correct before i buy them and treck many miles to pick them up?
    Here is a link to some i'm interested in...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=010
    Will these be ok?
    Also while i'm at it can i upgrade my stock "exclusive" suspension springs with say springs from an SRI and still use the stock shock absorbers, don't want much lowering either.
    TIA
    Here, there and every where!
    All the figures you have quoted are correct m8.
    110mm PCD 5 stud
    35-45mm offset
    65mm centre bore.
    Sri springs will fit but you would be advised to fit the shockers to match too It will be approx 30mm lower if you fit SRi springs
    Oct 2007
    Sector 7
    Cheers C,
    What does the bore size mean as this is never quoted in listings?
    Will the alloys in the listing i posted fit?
    cambs
    go for 18" but failing that go for17"
    the bigger the better
    Oct 2007
    Sector 7
    I need to swap tyres over, so can only be 16", thanks for the info tho!
    Quote Originally Posted by Hitman View Post
    Cheers C,
    Bore size is the centre of the wheel where it fits on to the hub. Those wheels have probably come off a Vec B but should fit.
    Quote Originally Posted by mhvcbv View Post
    I would have suggested that too m8 but as he wants to fit the original tyres it's a no no
    Regular Member Karl's Avatar
    Sunderland
    "IF" you don't manage to get a set with the correct centre bore, and say its BIGGER than expected you can buy what are called spigot rings......
    TBH if you go for pretty much any 16" VX rims you "should" be ok
    Oct 2007
    Sector 7
    Cheers for the help Guy's
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    I have a set of SRi springs up for grabs if you need a set. They came off my 2006 SRi which had only done 15,000 mls, as i've dropped her onto Pi's.
    Let me know.
    Snowman, you got your ears on?
    cambs
    how much for the springs and will they fit a 1.8 ls hatch
  1. Signa 18" alloys what tyre size help please
    By bigbrox in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2012, 22:00
  2. Tyre size on alloys vs steel wheels
    By fastbatard in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2010, 00:59
  3. what size tyres are the best for 18"alloys
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2009, 14:24
  4. Alloys and tyre size
    By lochgilp in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2007, 18:05
  5. 19" alloys info
    By dave collingwood in forum Vectra C / Signum Troubleshooting
    Last Post: 27th January 2007, 17:07
