Thread: Remote Locking
    Default Remote Locking
    OK lads, I'm at my wits end with it, heres the situation, got my Vectra with only 1 remote key which worked fine for about 2 weeks, then sometimes it would unlock/lock by remote, sometimes it wouldnt, then the dealer sent me the spare, which worked fine ever since I got it, while the original now doesnt work at all.
    so today I got a mk4 astra remote key and a mk5 astra flippy key for my mk3 astra, as the remote bits aint compatible with my car I decided to try the batteries in the vectra key that wasnt working, the astra batteries being identical to the vectra ones except the astra ones were Panasonic, the Vectra ones Sony, so tried it, key still would unlock car with any of the astra batteries (which are brand new), so put the astra batteries in the working vec key to see if it was because the batteries were incompatible, so the astra batteries in the working vec key unlocked the car, locked it, unlocked again, and when I went to lock again it refused to work.
    thought ****** it, put the 2 sony batteries back in the vec keys, tried them again, this time the vec key that wasnt working was now working while the other "good key" wasnt, thinking i'd put the batteries back in the wrong keys, swapped the sony's in the vec keys for each other and now none of the vec keys were working the car, so I swapped the sony's with each other again and am yet to try my good key with the definite original battery it had.
    completely scoobied, will be making the dealer look at it when it goes for its first service in 10K miles (currently on 20K) which wont be till about february. meanwhile need more ideas.
    HELP!!!!!!!!!!!!!!!!!
    Jeez, I got lost about half way, switching batteries n all that lol Can u get into the car now?
    yeh, using the door lock, and sometimes the key still unlocks, try to fix something and end up not fixing it and ****ing something else up at the same time.
    Hmm, its confusing, trying to think of something....
    ok, tried it again, no keys unlocked it, fired the key in the driver door lock, unlocked it, took key out, opened door, alarm went off, put key in ignition, took it back out, tried remote again, it locked, unlocked, unlocked boot, locked again, so so far touch wood it works. the good one that is.
    still clueless
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Jay
    LOL - glad I wasn't the only one. I'm reading it again now to decipher it!! LOL
    Full Member chunkster's Avatar
    North east HQ
    ouch!!! my brain hurts now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!let vx sort it
    Wayne -
    Regular Member barney's Avatar
    nottingham
    I had a simlar problem with both my vectra "b" keys (well I think ) it wasn't so much the batteries that were causing the problem it was the contacts at fault..I'd put new batteries in it worked then it wouldn't then it locked then wouldn't open and so forth...I found the fault to be the connections were not making a decent contact on to the batteries..
    I played about with them and got them to work fine.
    It worth giving it a go, it may or may not solve your problem.
    I think last night when my good key started working again the ignition had something to do with it.
    cudnt get it with the remote, so fired the key in the lock, took out, opened the drivers door and the alarm went off, put the key in ignition to turn alarm off, then took key back out and it started working??
    ach I dunno, basically theres no point me having a spare if it doesnt work tho.
  1. remote central locking
    By mifandmif in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2011, 23:57
  2. remote locking
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 09:35
  3. help remote locking
    By swvectra in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:45
  4. Remote locking (again?)
    By quba in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2006, 22:52
  5. Remote locking
    By IamtheStig in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2006, 21:21
