Thread: Couple of questions...
    Larkhall
    Default Couple of questions...
    For most of today the car has had quite a 'violent shake' when i start it up. It always starts first time but it's had a very quick turnover. I've notice it happen a few times over the past but today it's happened everytime i turn the key.
    Second point is the heaters - they have been whistling like mad and they are only on the first setting!!
    Any ideas??
    I'm beginning to think the cars' on it's way out
    Nicking Ya Dinner.
    Engine mounting
    Control unit going bad, it's behind the glovebox, looks like a big heatsink.
    Larkhall
    Is it an ECU problem? The ECU went on the Astra
    Nicking Ya Dinner.
    Na, one regulates the blower motor, I assume you mean that on position 1 it sounds like its on position 4 at the switch?
    The mounting if soft or shot will allow the engine to vibrate around, especially on starting and turning off the engine.
    Larkhall
    It's fine when switching it off, only on start-up
    Also, when the car is started for the first time after being off overnight or for a few hours it makes a fast ticking for a few seconds, is this the dreaded chain rattle......??
    Nicking Ya Dinner.
    How many miles has it done?
    It's more likely you are hearing an electric pump winding up.
    When you do a quick pull away do you hear any banging or vibration through the gearstick?
    Larkhall
    Quote Originally Posted by VauxVeteran View Post
    Its done 28500 and theres no vibration or banging when i pull away quickly. All the noises are during start-up
  1. A couple of questions.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 16:16
  2. Couple of questions
    By Pete1nlancs in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2010, 20:14
  3. couple of questions........
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2009, 14:55
  4. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  5. Couple of questions
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 01:35
