Thread: mod half way done
    Regular Member nph1's Avatar
    cheltenham/gloucestershire
    Eek mod half way done
    hi all
    well the leather back seats are in and passager front seat but have a shreaded head on the screw on the drivers side, its now to dark to carry on theres always one bl**dy one will have to drill it out tomorrow just hope i do it will out damaging the tread.
    post pics when complete.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You can buy a tool for that mate. It has a coarse reverse thread, you drill a pilot first and then screw it in. As the thread is reverse eventually it will start to unscrew the broken star drive head. HTH
    Thumbs up thankyou
    cheers bud need to get this one out first
    Here, there and every where!
    Quote Originally Posted by nph1 View Post
    What rushy was describing is a stud extractor and it is how you are going to get the remaining bolt out.
    Drill a hole in the remaining bit of bolt thread and insert the stud extractor. They have a left hand thread so as you unscrew it, it forces its way into the bolt and hopefully should remove it! A good soaking with WD40 helps too.
    Otherwise drill the bolt out, re-tap it then fit a new bolt
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by bailes1992 View Post
    If you got a dremel drill or maybe a hacksaw, cut a grrove in the top and remove with a large flat head screwdriver called Rodger
    So simple, but thats a great idea!!
    Done that a few times but if it's tight you can snap the head off (if it has not already snapped off)
    Default good idea
    i will try that hacksaw trick tomorrow
    cheers
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    you made that up?!?!?!
    Mar 2007
    Grimsby, Lincs.
    When it comes to problems like that, technical stuff etc. Hands on sort of jobs Im pretty good.
    that was sarcasm, engineers have been using that trick since before my great great grandad was born lol
  1. A job and a half
    By ed taylor in forum General Motoring Chat
    Last Post: 8th May 2012, 20:35
  2. anyone else half cut ?..
    By steveked in forum General Chat
    Last Post: 11th October 2008, 20:56
  3. half way done
    By lizard in forum Styling
    Last Post: 13th July 2008, 06:09
  4. The Half-Wit
    By fields in forum Comedy & Humour
    Last Post: 31st January 2008, 11:44
  5. The Half-wit
    By Gaz the Cab in forum Comedy & Humour
    Last Post: 13th January 2008, 10:03
