Results 1 to 3 of 3
Thread: Where my oil filter? 1.9 CDTi
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    Question Where my oil filter? 1.9 CDTi
    Hi All
    Ive Just purchased all the servicing bits for my signum, looked at the oil filter and its not the usual metal type. i take it that its internally fitted?
    Anyone know where i should start looking?
    Woodsta
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Yep - it's a sod to get to
    Right at the back of the engine at the bottom,in a housing with black screw 0ff lid (32mm head if i remember) and a small tube coming out of it which lets the oil drain before the filter is removed
    I find that you have to take the under tray off if you are doing it on ramps or a jack because the hatch in the middle won't lower enough for access unless it's on a lift - also do the filter before the sump plug or you will keep getting oil running down your arm
    May 2006
    Kent
    NICE ONE!!!!!!!
    BIG THANKS.
    Woodsta
  1. Help!!! CDTi oil filter
    By 123rado in forum Engine & Drivetrain
    Last Post: 17th March 2012, 18:58
  2. cdti air filter help
    By chris1984 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2012, 19:51
  3. 1.9 CDTi oil filter
    By dalcock in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2010, 18:43
  4. What oil filter for 1.9 cdti 150 ?
    By Fash in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 20:04
  5. V6 CDTI Air Filter
    By r.bailey63 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2007, 01:16
