Thread: error lights
    Regular Member leeandjude's Avatar
    Feb 2007
    boldon, sunderland
    Default error lights
    got a problem on the car..only started two days ago but when i start the car, the ABS and traction control light stay on for about 10 seconds then they go out. after about 2 mins they come back on and stay on.
    I have checked if the traction control is really off and it is.
    I know i can still drive the car but but uneasy about it. Dont know if this is related but the warning light flashed on for the radiator water (checked and ok) and once the engine oil light came on (checked and ok)
    Good job i have a warranty with the car!
    only mod been done in last couple of weeks is fit the 302mm brakes and calipers, wich i had to slightly bend the metal around the ball joint cos it was rubbing against the disk. have i done anything wrong?
    F'ing car!
    Here, there and every where!
    Sounds like you have damaged the wire to the brake sensor m8 Get it replaced, it's not that expensive from the stealers
    [Ex]Admin Duncan's Avatar
    Wouldn't that have just brought up the brake pad message in the info display though? I don't recall it bringing up the TC/ABS light.
    I'm sure i read somewhere that the brake sensor lead can throw up all sorts of errors if it is damaged
    I might be mistaken though................it has been known
    Feb 2007
    boldon, sunderland
    actually question to you dunc....the guy who fitted the brakes said there was no where to attach the brake sensor..is that right?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    the brake pad sensor wire attaches into the brake pad itself... but cant see this being the cause of ABS/TC problems.. more like one of the sensors on the hubs may be damaged? The ABS has its sensors built into a ring on the hub itself i believe.. all the pad wire would do would bring up a pad warning light depending on which type of infotainment unit u have fitted.
    Quote Originally Posted by leeandjude View Post
    He's talking cobblers I'm afraid! I had the brake pad wear sensor fitted when they were on my car. The wire is only connected to the passenger side caliper.
    Quote Originally Posted by plasma View Post
    That's what I was wondering!
    Yep, as above that's all I recall it ever doing.
    Feb 2007
    boldon, sunderland
    thought so!
    cheers guys (and dunc!!)
    off to make a warranty claim...again! got another problem too but will post on a seperate thread
    Regular Member jonnye's Avatar
    Feb 2006
    Derby
    now thats funny my traction light came on 2 days ago and also the power stearing lights on too
  1. DAB box error
    By carlton in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2016, 08:55
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. which error?
    By steve1412 in forum Engine & Drivetrain
    Last Post: 9th February 2011, 20:00
  4. Help!! Error CD?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 18:36
