Results 1 to 10 of 24
Thread: Wiring diagrams or/and help please ?
    Hertfordshire
    Default Wiring diagrams or/and help please ?
    Hi people, I'm after a bit of help here.
    I have found that the ignition switch is all canbus wiring, which is a bit of an issue for me.
    I appreciate a lot of this will be canbus wiring but at some point, probably when it comes out of a fuse box, it must go to 12v supply somewhere ?
    Does anyone have any wiring diagrams for the Vec C, specifically related to the ignition circuit.
    What I am really after is the conventional 12v side of things, specifically:
    the auxiliary ignition circuit (key position one, turns on the heater controls etc)
    the main ignition circuit (to power the ECU, ignition etc, anything else required for it to run)
    and the starter circuit (to actually crank the engine over)
    Any wiring diagrams related to the above much appreciated or any hints as to where on the car this wiring can be found.
    Even any hints or links as to where I might find what I am after.
    I know there is the immobiliser issue as well, but that one I think is easy enough to sort out.
    Obviously it is not such a good idea to post this type of info on an open forum, so please use PM or better still email on greengrowler@ vectra-sport.com (leave the space out)
    Many thanks in advance guys.
    Hertfordshire
    Can anyone with TIS at least tell me how to get the ignition switch of the column please ???
    Looks like I may have to take the wheel off to do it but would like to know for sure before I take this route, cheers.
    Hertfordshire
    Hellooo..........lol
    I have TIS GG, but damned if I can work it, would help you if I could, if you tell me where to look I will ...
    Sorry GG, I don't have a TIS, but I'm intrigued about what your trying to do.... the only thing I can think of is maybe you are wiring in a remote starter to get the car toasty warm in this inclement weather??!?!
    Hertfordshire
    Cheers Bainie, but I've never used it lol, wouldn't know where to start with out seeing it.
    Jamie, yes m8, time to wire in the rest of my Clifford, it came with all the parts, but did not complete this side of things for warranty reasons as much as anything.
    Remote start it is, had on my Vec B and I so miss it, I'll be damned if I'm gona keep scraping windows, lol.
    Someone must have TIS, and know how to use it, lol. ?
    Quote Originally Posted by Green Growler
    LOL, or someone tell me how to work it ??? I can get labour times, thats it ??
    Hertfordshire
    Quote Originally Posted by Bainie
    Ok, so how long will it take me to get the ignition switch off the column then ???
    Regular Member Inspektor's Avatar
    Northampton (Santa pod)
    I thought I was alone. Thankyou
    Sunny Aberdeen
  1. ECU Light on, accelerator pedal fault? need wiring diagrams
    By Mr.Matt in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 14:23
  2. Insignia radio wiring diagrams
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2012, 14:30
  3. Fog Lights Wiring Diagrams (Pictures)
    By Silver Vectra C in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2007, 15:44
  4. Anyone got Vectra C wiring diagrams on TIS or similar ?
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2006, 22:16
  5. Vauxhall TIS 2005. Diagnostics, labour times,wiring diagrams etc etc
    By Robbieben in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2006, 18:02
