Thread: wire harness help?
    Default wire harness help?
    guys what are all the wires for ?
    i've just bought myself the facia kit and the harness but can't work out what all the wires are for see below[IMG][/IMG]
    any help will be great
    liam
    Regular Member philzi's Avatar
    East Yorkshire
    The wires in the harness are the permanent live and switched live.
    You need to look at your headunits harness to see where the switched live and perm live connect.
    You can then place the cables into the ISO connector.
    Some aftermarket headunits allow you switch round the perm and switched live using bullets. The VX cabling is the alternative.
    it was more the cables with the question mark by them i was trying to find out what they are for - the bottom set are the power and speaker cables but what are the top ones ?
    East Yorkshire
    the bottom one is power only
    one of the top ones will be the speaker connector.......
    the third one....good question.....
    [B][SIZE=3]also does anyone know what areas the colours on the speaker cable represent front right, rear left etc etc
    East Yorkshire
    The cable colours may be different but this shows the pinout for a standard ISO DIN speaker connector...
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Quote Originally Posted by philzi
    Where do I connect the power lead? does it have to run to the battery? Its a pioneer head unit if this helps
    Regular Member Cheeky_B's Avatar
    Irvine, Scotland
    I just did mine mate, i live in irvine. PM me if you need any help.
    Billy
  1. abs harness
    By stret in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2013, 21:07
  2. Do I need a Wiring Harness?
    By weidass in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 22:17
  3. Hid relay harness
    By suggs1971 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2010, 19:43
  4. If I change to Pioneer DEH 70BT do I need just facia or wire harness too?
    By Rikkiola in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2006, 22:44
