Results 1 to 10 of 11
Thread: Signum Headlights....
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    Default Signum Headlights....
    Hi all,
    The factory fitted bulbs in my face lift signum headlights are p**s poor. Can they be changed for anything brighter - the ones on the mrs's Yaris put ti to shame!
    sure can...there are quite a few threads on here for upgraded bulbs.. IIRC Phillpis silvervisions got quite good reveiws..
    May 2007
    How easy are the bulbs to remove? Looks kinda fiddly to me?!?
    it's easier if you take ( on the nearside) the windscreen washer filler neck out ( just pulls up ) then there is loads of room.. On the driverside remove the airbox to give you plenty of access.. it's a job for a 3 yearold otherwise as there is minimal handspace...or.. if you really don't want to struggle....remove the front bumperskin and just take the headlamp off..you can swap the bulbs in the lounge then..
    May 2007
    thanks for that, I'll get my pianists fingers out later on - what bulbs you think are the best?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Quote Originally Posted by andrew the bobby View Post
    You'll probably start an argument, as it's down to personal preference. Phillips Vision Plus did it for me, though. I still miss the Xenons I had in my Omega, though!
    Phil
    Jul 2006
    You can upgrade them, and they are fiddly, especially on the facelift cos you have to remove the whole bumper.
    Sadly, you can't actually see any further with the new bulbs due to the headlamp design
    Luton, Beds
    Quote Originally Posted by parapaul View Post
    You can on the pre-facelift, plus you don't need to remove the bumper. You'll need to have some antiseptic and plasters available, though........
    Phil
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    or hands like ET
    Luton, Beds
    Quote Originally Posted by Ian S100 View Post
    or hands like ET
    That's true. the light up finger would help you see into the dark corners!
    Phil
  1. Signum headlights
    By Andiman in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 20:49
  2. Headlights on the Signum
    By antix_v2 in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 20:01
  3. signum headlights
    By n3cya in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 12:50
  4. Signum Headlights
    By s1nglef1sh in forum Styling
    Last Post: 21st April 2009, 22:06
