Thread: Air re-circ mechanism noise
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Air re-circ mechanism noise
    When I press the air recirc button on the dash, there is a strange noise, I will describe it a d,d,d,d,d,d,d (go with me here!)
    When the button is pressed again (ie to switch it off) there is a different noise that sounds like c,c,c,c,c,c,c,c
    Both last for a couple of seconds with no noise afterwards. The air recirc works fine, just with these noises.
    Any one got any ideas how to get at the flap that moves and check for dirt, issues ??
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I had the same; they replaced a part behind the glovebox (was under warranty)
    scotland
    when this button is pressed should a light on it come on??? as mine doesn't .
    sorry I know this aint helping you but thought i'd ask as its same topic .
    Quote Originally Posted by Ste View Post
    It sounds like the servo motor pack is pulsing Ste...had it on all our veccy's..
    Regular Member cheekylemon's Avatar
    Aug 2007
    Droitwich - Worcestershire
    Quote Originally Posted by gsxrster View Post
    The light will only come on if the air recirculation can initiate. IE, if you have the fan blowing on the windscreen, the air-recirculation will not come on. Have a quick check and make sure you have it blowing out of the dash.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Well, I have removed the offending part and had a look at it.
    Inside there are several plastic gears driving the actuator arm from a single DC motor.
    On one of the gears a tooth has chipped off, and this is causing my woes.
    Clearly this be not be repairable, so a new part is necessary.
    Just for completeness of this thread.
    1 what a pain it is to get it off the blower assembly (little clearance around it) - it is possible to remove this part without removing anything other than the glovebox.
    2. The writing on the side is
    Valeo, 006972T, GM, Type-1 11V, 100-0024-01-0 Made in China. 0110031A
    Wiltshire
    Are these bad boys expensive? I have the same on my Vectra, if you turn the CC knob right down you can see it spin round to a certain point and then stop but the servo clicks quite softly. When you turn the temp back up it goes back and when it stops it clicks loudly!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If it's the same part as what failed in mine (the re-circ actuator motor) it is about £60 for a new one.
    Mine is still not changed, I have tied up the flap arm so it is permanently on not re-circ.
    Wiltshire
    A quick update.
    Vauxhall have just replaced the servo motor under warranty (the car is a 55 plate facelift with 46K on the clock).
    They are also gonna replace the electric tailgate struts under warranty as I have had a few intermittent problems with it.
    Thumbs up to Platinum Vauxhall in Chippenham!
  1. Glovebox knocking re-circ air part number help please
    By portreathbeach in forum Vectra C / Signum Troubleshooting
    Last Post: 15th March 2012, 10:12
  2. re circ valve
    By vectraedition100 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2012, 21:41
  3. noise coming from the air circ fan
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 12th July 2007, 17:30
  4. Replies: 0
    Last Post: 25th June 2005, 16:11
100-0024-01-0
valeo 006972t
