Thread: Cruise control issues
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Cruise control issues
    I have had intermittent cruise control issues, especially when hitting the 'decrease' button - it normally turns off the CC, and hitting the 'resume' button it normally takes a few hits for it to do anything, and then it just normally sets the speed to the current speed (ie does not revert back to the previous preset speed as it should)
    Note that these operations are the SAME button.....
    I was playing with the stalk buttons the other day and found that if I gently pulled the 'OFF' button out more than the spring loading had, then the other button worked fine.
    I suspect that the 'OFF' button is either not releasing properly and can then be 'triggered' easily when pressing other button (possibly with the movement inside the stalk end as the button is pressed in), or is dirty and only takes a minute movement / pressure to trigger it.
    Just thought I would share this with you lot....
    How do the button at the end of the stalk come out so I can clean the terminal contacts??
    Jul 2006
    Quote Originally Posted by Ste
    ..hitting the 'resume' button it normally takes a few hits for it to do anything, and then it just normally sets the speed to the current speed (ie does not revert back to the previous preset speed as it should)
    Mine's never done that either. I know it should, but it doesn't. If I press the resume button, CC kicks in at whatever speed I'm doing at the time.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by Ste View Post
    I gave this a try on the way home last night & it worked - it's still not 100% but not far off -Top man, cheers, the only problem now is I'm booked in for a new stalk under warranty in a couple of weeks
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    That'll prob cure it if it is the stalk at fault.
    Mine's out of warranty, and I'll take a look later.
    Jan 2006
    Skynet HQ EMEC#5
    I had not used the cruise control for a while, came to use it & set button wouldn't work. when I was parked up I gave the buttons some generous presses in case contacts were dirty.
    It's been ok since.
    When using mine, the decrease button is the one that sets cruise control at last speed setting.
    The increase button only sets it at your current speed.
    West
    Quote Originally Posted by Ian T View Post
    Mine too
    Mar 2007
    Southport
    Mine too
    Ditto
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Mine used to be a bit unreliable when I didn't use it much.
    Now I'm on the motorway every day, it gets used almost daily and never gives a problem. I suspect the switches are a bit prone to problems, apart from the known problems with brake and clutch pedal switches.
    Phil
    [Ex]Admin Duncan's Avatar
    I've had that happen in the past, usually when I'd clicked the decrease button a few times repeatedly to reduce the CC speed - the CC would disengage. Hasn't happened for ages now and yet nothing was done to it - i.e. wasn't taken to the dealer to be looked at and I didn't have a twiddle myself - so I never did know what caused it. All I can suspect/suggest is a slightly dirty contact?
  1. Cruise Control issues
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 19:14
  2. Cruise control
    By br4duk in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2011, 15:22
  3. Cruise control and engine temp issues
    By zerocool in forum Engine & Drivetrain
    Last Post: 3rd February 2009, 02:01
  4. cruise control??
    By Mads in forum General Chat
    Last Post: 6th July 2008, 11:47
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
