Thread: G-max Springs
    Regular Member pmw123's Avatar
    lancaster
    Default G-max Springs
    Hi
    What Do You Think About G-max Springs Are They Good Or Bad Any Problems With Them
    Cheers Paul
    had a few sets in the past.. not given the 'best' ride quality, but were cheap at the time.. Now we've used Eibachs they seem to give a much better ride...
    lancaster
    HI MARK
    JUST FOUND THIS LINK ABOUT A MEMBER THAT BOUGHT SPRINGS FOR A 1.9CDTI BUT WHERE FOR A 2.2DTI DIDNT YOU SAY TO GO FOR THE AXLE WEIGHT SO THEY SHOULD HAVE FITTED PREFECTLY http://forum.vectra-c.com/showthread...highlight=GMAX
    SORRY TO BE A PAIN JUST WANT A 40MM DROP ON A 1.9CDTI
    CHEERS PAUL
    Jamesy bought spring's that wheren't for the correct axle weight...
    if the springs are for your car then they will give you that 40mm drop you need..problems arise when you get some springs that are 'close' in weight but not ideally for the car..Read your front axle weight off the chassis plate.. then try and find springs that are for that weight..
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
