Thread: Door speakers
    Regular Member skinnyseand's Avatar
    HASTINGS
    Question Door speakers
    I want to change my door speakers to aftermarket speakers. Do I have to take the door panel off in order to remove them or can I remove them through the speaker grills?
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    door cards have to come off. fronts are easy. but you will need a bit of patience for the rear as their is a sirclip on the rear window winder, you cannot remove the card until that is out. the circlip just slides forward (back, dependin which way your facing) and it can be done with a small flat head screw driver or slightly larger, but try not to damage anything. also the bit where the door handle is on the inside of each door needs to be taken off to get to TWO torx screws they are size 20-25. Basicly the bit on the door that you hold onto to pull the door shut or to hold on tight if someone is driving like a nutter, you need to get at that with something that will not damage it or it'll cost £15 as someone on here found out to there expense.
    HASTINGS
    Thanks Silver. By the way my team is going to cream yours today.
    Jul 2006
    mmmmmmmmmmmm
    ha ha... we shall see!!! we are rubbish at the mo, so it wouldnt surprise me.. But could there be an upset like at man city? very good start for them.
    HASTINGS
    Do you have any grill? available among the parts you are selling
    Jul 2006
    mmmmmmmmmmmm
    Quote Originally Posted by skinnyseand View Post
    unfortunately not mate. soz
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I changed my front door speakers to Alpine components with crossovers - the improvement was marginal & not really worth all the agro
    Regular Member siross's Avatar
    Oct 2007
    Quote Originally Posted by Ian S100 View Post
    It all depends on how they are installed, aftermarket speakers are designed to be amped, so if they're not they wont sound particularly brilliant.
    Also, sound deadening, sealing doors and mounting speakers properly and solidly is essential, otherwise you may just be dissapointed with the end result.
    Imo, if you're going to the trouble of putting in aftermarket speakers, take your time, install them properly with a nice amp to power them and you will be impressed!
  1. For Sale: Speedo / Door Speakers / Door Tweeters & Boot Lock Mechanism
    By Woody in forum Parts for sale
    Last Post: 21st March 2013, 01:15
  2. door speakers
    By WiCkEdOnAmIsSiOn in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2012, 05:53
  3. door speakers
    By chrosty in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 16:16
  4. Door Speakers
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2007, 20:43
  5. Door Speakers
    By Fireyfella in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2007, 09:50
