Results 1 to 3 of 3
Thread: Noise from brakes
    Feb 2007
    Wolverhampton
    confused Noise from brakes
    Hi guys had my front discs and pads done around 2 months ago and they have been squeaking ever since, so i used gsi3.2's guide to get the pads out (surprise surprise not a hint of copper slip) gave the backs a smudge of copper grease and slipped em back in, all went swimmingly and the squeal went, however now i'm getting pretty loud groaning/scraping sound from the drivers side wheel, when accelerating or coasting but it stops when actually braking, gonna pop the wheel back off tomorrow and check all is well, any idea what to look out for please?
    if they didn't grease the pads...did they clean the pad carrier with a wire brush to remove all the old, baked on brake dust??..Did you smear copper grease on the 'ears' of the pads where they touch the pad carrier?? I think what you've got is a sticky pad...
    Feb 2007
    Wolverhampton
    Thanks Mark, will try that today
  1. Got a grinding noise from back brakes ,Help please
    By philgst in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2011, 18:54
  2. Noise from brakes
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2010, 05:36
  3. scraping noise with brakes
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2009, 20:41
  4. Noise from brakes
    By Stano in forum Suspension, Wheels & Brakes
    Last Post: 20th September 2007, 20:33
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
