Results 1 to 10 of 13
Thread: Parrot Ck3100 Kit 2007 Help Needed
    Regular Member mushy2007's Avatar
    Liverpool
    confused Parrot Ck3100 Kit 2007 Help Needed
    Hello All,
    Before any one mentions it I have searched the How 2 section and am 95% happy with what i need to do to fit the kit.
    However can someone explain what cables need connecting to what.
    I have the full parrot kit and the ISO lead to VX cable.
    Am I right in understanding you only have the ignition live to connect up with the rest being plug and play.
    Any help would be great.
    Cheers,
    Mushy
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If you have the parrot adapter lead you should only have to get the ign feed from the cigarette lighter, all the rest should be plug and play as you say.
    Southampton
    I found it was an absolute **** to fit the iso lead into the space behind the radio .
    If I was to do it again (which I wouldn't!) I would take the 3 wires (speark+, speaker- and mute) from the ISO lead and put them directly into the VX wiring pin (as there is space) - so no SOT lead at all.
    Redhill
    yeh its fun this Cambus wiring now... i'm still not got round to fitting my parrot yet...
    Liverpool
    Quote Originally Posted by tyreman View Post
    Cheers Tyreman.
    Let you know how I get on.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by Rockster View Post
    same here
    Midlands Mod Shop - NFFC.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Can-bus is fine,if a wire looks skinny for the job it's doing stick a multimeter on it just to confirm the voltage,that way nothing melts!
    May 2007
    Scotland
    Quote Originally Posted by teilo View Post
    So is this a relatively easy way to do this. I have a 3100 on the way but have ordered no lead as yet. If this is straightforward then is there a wiring pic to refer to ?
    Tone
    Redhill
    i have just got around to fitting mine... at the moment i have just used the autoleads adapter from halfords for the radio, then ran a switched live from the aux. socket near the gear stick, and wired that in to the autoleads connector, if you use the BMW one rather that the one for vauxhall, you get the extra leads you need..
    then the parrott plug straight in, but you will need to remove the glove box and pull all the lead through from the radio, otherwise you have no chance to get the radio back in...
    Southampton
    Quote Originally Posted by tone View Post
    Its really easy to do - but you need some extra "pins" to put in the vauxhall harness that you can attach the wires from. No doubt some electrical store like RS or maplin would have some - as I have purchased a lead - if I needed to pull the radio out and replace it I would butcher the lead I bought.
    With the SOT122 lead I found there was not enough room to pull the cable through from the glove box.
  1. Parrot CK3100
    By blackviper90210 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd November 2012, 19:57
  2. For Sale: parrot ck3100
    By Critch in forum Parts for sale
    Last Post: 21st August 2012, 21:49
  3. Parrot ck3100
    By nick-v2.2 in forum General items for sale
    Last Post: 16th April 2009, 13:20
  4. Parrot CK3100
    By Perry in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2008, 12:09
  5. Parrot CK3100
    By GARY3306 in forum Parts for sale
    Last Post: 1st August 2007, 23:18
