Thread: Problem with alarm
    Oct 2006
    NEWCASTLE UPON TYNE
    Default Problem with alarm
    Hi just wondered if anyone has had this problem......
    I have a 52 plated Vectra C sri and
    when I switch on the ignition I get a warning on the display which says " Check Safeguard".I have tried what the handbook says but it still comes on.Any advice would be apreciated.
    if it won't reset as the handbook suggests, then it's a trip to the dealer to see what bodycodes are logged and why the system is throwing a wobbly...
    Oct 2006
    NEWCASTLE UPON TYNE
    Was hoping I could solve it without a trip to the dealer,
    Thanks Mate.
    if it won't reset, you could try the homebased ECU reset.....
    disconnect the battery on the car for around 15 mins ( this will reset all ecu's to factory settings) then reconnect the battery...
    If the fault is still present, you'll still get the message and it'll have to go to the dealers...or, if you're lucky and the fault has 'fixed' itself, then it may stay off..
    before you disconnect the battery thou, make sure you have the radio code in case it decides to ask for it..
  1. alarm problem
    By gkr67 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2010, 02:18
  2. Another car alarm problem
    By suggs1971 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2009, 21:36
  3. Alarm Problem
    By KSD in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2008, 14:58
  4. Alarm problem
    By fishphone in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2007, 19:50
  5. alarm problem
    By stevietiger in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2007, 12:15
