Thread: 1.9 CDTi 150 no power when cold.
    Southampton
    Default 1.9 CDTi 150 no power when cold.
    Leaving work the other day I misjudged the speed of another car approaching the roundabout so had to engage FUR mode (floor it and let traction control get me out of the way).
    I avoided the car but I had to change gear a 4000rpm in first as the car had no power - normally the power is still coming in a 4000rpm.
    Coming off the roundabout I had another play in 2nd gear to see if it was a once of and the same thing happend looses power at around 3500rpm and crawls to 4000.
    Tired the same thing this morning when the engine was cold and the same thing happens. Once the engine is warm everything is fine.
    I know the newer tuning boxes protect the engine when its cold but I didn't think the standard ECUs did this? Is this the case - I've not read anything about it - or is there something wrong under the hood
    Regular Member benny's Avatar
    Feb 2006
    dudley
    "some cars" suffer with sluggish altonators when cold so they hold back a little or misfire slightly ....this is normal for "some cars" and there isnt a fix for it some thing you will have to live with im sorry to say ... if some one on here or you know has a uptodate copy of tis they will be able to find a tech referance to it for you ......
    Apr 2006
    Quinton
    i might be wrong - I'm sure someone will either confirm or correct me - but I thought the standard ecu gave protection when cold on the ecu.
    Not that I've ever tried to get mine that high whilst cold but I'm sure i read it on this forum somewhere.
    HTH
    Nick
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by Nickzx6r View Post
    HTH
    Nick
    Pretty sure your right on that
    May 2006
    Nottingham
    Yep, as Microsoft would say "It's by design"
    Andy
    Southampton
    Thanks guys, at least I know there's nothing wrong
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. No power pulling off when cold??
    By digitalinkjetman in forum Diesel Engine related
    Last Post: 11th December 2011, 12:45
  3. Replies: 6
    Last Post: 11th March 2011, 21:13
  4. no power from cold start
    By gazthebigyin in forum Engine & Drivetrain
    Last Post: 8th February 2011, 00:30
  5. cdti lacks power when cold, & engine light on
    By mr_dog in forum Engine & Drivetrain
    Last Post: 8th February 2010, 22:45
insignia no power when cold
1.9 cdti lack of power when cold
