Results 1 to 10 of 15
Thread: Help!!!
    Oct 2007
    chesterfield
    Default Help!!!
    Hi guys,
    just service my 2002 52 plate 2.0 dti vectra C and now the car and spanner light is on can this be reset without having to go to vx?
    It came on after i changed the diesel filter............is now in limp mode permanently i have no idea whats up?help!!!
    1st.. service light...
    sit in the car and press the brake pedal and the button on the speedo down and hold them both down.. now turn the ignition key to posn 2 and keep holding the pedal and button down...after about 30 seconds it will reset....
    Limp mode...do you have a car and spanner light on the dash or is it just sluggish...if it's got the light on then it's got a fault so it will need fixing before it goes off..if it's sluggish then i wonder if there is still air in the fuel or filter... or the seal may be wrongly seated and allowing air in to the filter...the only way to be 100% sure is to get the fault code read...and that needs a codereader that is CANBUS compatible...
    Oct 2007
    chesterfield
    The light is on all the time. could this be that its pulling air into the filter housing (ie. the sensor ontop of the filter is setting the light off???)
    Oct 2007
    chesterfield
    thanks for the reply by the way!
    it could well be the reason why..it would be worth a check,,..
    don't forget to top the filter right up with clean diesel before screwing the lid on..and check the security of the plug on the top..it does seem to be co-incidental...
    Quote Originally Posted by inneedofhelp View Post
    it's what we're here for..
    Oct 2007
    chesterfield
    will the light go away once the fault is rectified?
    Oct 2007
    chesterfield
    or will it still need a reset? i.e. how will i know if ive fixed it?!!!
    the fault light will go out when the problem has been cured..but it will illuminate every time the car is started for the next 25 restarts after the fault is fixed as the car will store the fault code that long.. so if it's not on when the car is running, the fault is cured..
    the service light will only go out if you reset it as detailed above..
    Oct 2007
    chesterfield
    plug on top?
    is there a workshop manual anywhere on the net that you guys download?
