Results 1 to 10 of 13
Thread: Power Steering Problem
    Aug 2007
    Neath
    Default Power Steering Problem
    I have had a problem for some time with my Vectra 03 plate 3.0 CDTi and it is slowly getting worse.
    When driving, usually at slow speed, initially the traction control warning light comes on. This is followed within a few seconds by the power steering warning light appearing. At first the power steering seemed fine, but now occasionally the steering does become heavy at very low speeds. The other strange thing that happens each time is that, when the warning lights are on, the direction indicators no longer self cancel. Self cancelling is fine when the warning lights are out.Two visits to a main dealer have resulted in a loose connection in the steering wheel being diagnosed, but this being 'fixed' has not helped. Any ideas?
    Thanks.
    Jul 2006
    Mexico
    Probably needs a trip to the dealers mate, sounds like a faulty CIM module to me, hope you sort it soon
    yep, code reader time..
    Aug 2007
    Neath
    Thanks for that. It's what I expected - just hoped I was wrong
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    could be worth getting the alternator checked as i heard that the alternator can run extra power to the pump etc hope you get it sorted fella
    Apr 2006
    Kent
    Wow, I have the same problem! my 04 has just started to display the traction control light every now and then. And also the Powersteering light, but also my AFL's work intermittenly?
    What was you resolution?
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Both sound like the alternator to me as the power steering stops when they are not charging and also other systems detect low voltage so bring on warning lights.
    Cim or steering angle sensors
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I started to have this problem, so looked into replacing the cim in the steering column myself. Think it was £250 +vat just for the cim module. You will also need two tech 2 session's at about £50 a pop. Although the first one is just to reset the fault I think so a simple battery off for 15 mins should sort that. I believe the cim also houses the steering angle sensors hence t/c and power steering lights. Anyway, the fault seams to have disappeared, so it might have just been a lose plug.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    What is this "CIM" module and where can I find it? I am having these self same problems.
    Cheers.
    Paul
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering problem
    By delete1 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 20:41
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
