Results 1 to 10 of 20
Thread: Road Noise
    Oct 2007
    Bucks
    Default Road Noise
    I get quite loud road noise between 30 and 40 mph, a sort of droning, a bit similar to that mentioned in this thread:http://www.vectra-c.com/forum/showthread.php?t=31580.
    My Vectra is only a year old though, with 22K miles, and is Auto.
    It has the 18" 11-spoke rims with 225/45 Michelins on the front, Bridgestones on the back.
    Do these symptoms suggest flat spots on the tyres, or can wheel bearing go wrong after such a low mileage? Or is it a 'feature' of Vectras?
    Here, there and every where!
    Wheel bearings can go at any mileage m8 It could be that or more likely to be the Bridgestones. Loads of people on here have had them changed as they are so noisy
    Regular Member Auto-Brite's Avatar
    Staffordshire
    Ive got a droaning noise on my vec at the moment! Its ****** ****ing me off! It seems to be coing from the back o/s and its really noticeable about 40-50mph,its like a whooo whooo whooo then a humming!!! Do i check the rear tyres 1st??
    Mark
    Feb 2006
    Dorset
    I had my front drivers side wheel bearing go at roughly 28k , so it could be that . although my dealer didnt beleive me until the bearing was realy making a drone
    Regular Member Karl's Avatar
    Sunderland
    I would just dynamat the floor pans and rear arches, works a treat for minimising noise intrusion.
    Full Member stuart bigboy's Avatar
    May 2007
    kent
    i hav ea similer noise on my gsi have had all new tyres but noise stilll there its in the stealers today hopefully they will sort it out
    Regular Member SignumPhil's Avatar
    Luton, Beds
    I had a droning noise in mine, but I turned off Radio 4!
    Phil
    May 2007
    kent
    just got car back from the stealers needs nearside wheel bearing cant get one for 2 days so no going to be without the car again
    Jul 2006
    uh oh....
    I've had the same noise as everyone else......droning from the rear at 40-50, which seems to change with road speed till its a steady hum at around 70.
    It only started after having these alloys fitted though - I'd just assumed it was extra road noise after changing from 225 wide F1's to 235 wide T1-R's.
    Oct 2007
    Bucks
    Thanks for your comments.
    As my 'drone' seems also to come from the back, and the Bridgestones are on this axle, do you think it would be worthwhile swapping the front axle wheels with the rears? I'm guessing that this would prove whether the tyres are the problem or not.
    Having said that, I did not notice the noise when I went out this evening!
  1. Road Noise
    By Andyjarvis in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2012, 16:53
  2. No more road noise
    By ShamusUK in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 06:52
  3. road noise
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2011, 11:12
  4. Road Noise
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 23:11
  5. Road Noise
    By IBarfoot in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2007, 13:52
