Thread: Amp & speaker help
    Regular Member lochgilp's Avatar
    argyll
    Default Amp & speaker help
    Hi guys, i have a Kenwood ddx-6029 multimedia headunit wired with an Jbl active sub, but want to power it with a 4 channel amp and new speakers to get the best out the headunit
    Anyone got any advice or recomend speakers that will fit straight in without adapters and a good amp as im totally confused with all the choice thats out there
    Any help would be brilliant
    cheers
    Scott
    Feb 2006
    Dorset
    You could try running the standard speakers off an amp , they aint bad , and acousticaly matched to the car , although pioneer to a set of Q series speakers designed for vauxhall , i amped the standard speakers in my c-max and was quite surprised , they sounded brilliant , had HPF set to 60ish hz though so they didnt have to do serious bass , the sub looked after that.
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    For speakers i used Alpine Type R 16.5 cm all round, fronts were component but rears normal. Pretty much went straight in they came with an adaptor that fitted well but did cut the door hole slightly as they are (_) shaped door holes (Had a rattle and this had caused it but dont think it did - so prob not needed).
    As for Amp you may as well stick with kenwood then you can get the link lead so all amp settings can be adjusted by the head unit which is usefull. I wish i had done this as got the older DDX-6027 unit but all amps etc are Alpine so cant adjust them from screen
    Sounds good though (Apart from boot rattle)
    Regular Member NI-2.2SRI's Avatar
    Northern Ireland
    heard bout the leads an the kenwood setup for adjusting the settings, sounds quite cool. you could probably fit nearly ne speakers to your doors n e gud car audio retailer shud do adapters, i know the one i use does, bout 15 r 20 quid, they screw in then screw the speaker to them, i had to make my own thou, put in slighty bigger an deeper speakers, polk momo, competition stuff lol, then 6x9s on shelf, no need to worri bout adapters lol
    Jul 2006
    Right.
    THESE are the custom fit Pioneer components...currently £89.99 from Car Audio Direct.
    Pioneer TS-Q172C Vauxhall
    Features
    Frequency response: 35 - 28.000 Hz
    Sensitivity (1W/1m): 89 dB
    Maximum input power: 220 Watt
    Nominal input power: 50 Watt
    Woofer size (cm): 17 cm
    Woofer material: KEVLAR® brand composite cone woofer with butyl rubber edge
    Tweeter size (mm): 25,0 mm
    Tweeter material: Soft dome tweeter with Neodymium Magnet
    Fits Pre-Facelift Front doors, Facelift front and rear doors.
    HTH
  1. DVD speaker help............
    By carperjake in forum The 'Off Topic' room
    Last Post: 4th January 2013, 21:35
  2. Speaker Adapters.
    By g33had in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2010, 04:14
  3. 7th speaker
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2006, 08:20
