Thread: Astra/Vectra Airbag...
    Default Astra/Vectra Airbag...
    Is the Steering wheel off the current Astra the same as the Vectra...?
    I've got a Vectra VXR steering wheel, but no airbag, although I do have the pink and yellow plugs on my current one, all I need is a 2006 onwards airbag... Have found one on ebay, and looks the right design, with the horn symbol at the bottom of it, but shoudl this be the same as the Vectra one...? I know the Astra VXR steering wheels fit the Vectra, so I'm hoping it should be ok....?
    Anyone confirm or deny....?
    Cheers guys
    Penfold
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Hi Penfold, I have a similar problem, im after a Drivers airbag for a 2006+ Vectra Facelift and I have been told that the Astra Airbag will go straight on and the shape and design is identical, however, I have been told by a mate at Vauxhall that its not wise as the codes are different, meaning that there is some setting somewhere thats not the same, meaning that when you are driving, it could go off, or it could totally blow the Airbag ECU Module, causing your to pay crap loads of money to get a new one. Thats my situation so am holding out for the right one. I would hold out for the right one too, to ensure you dont screw up anything else on the cars management. Hope this makes sense.
    Cheers mate, I'll stick to a vectra one then definitely...
    Birmingham
    Let me know if you come across a spare one. Thanks.
  1. Astra g airbag ecu into a vectra c
    By Markt8 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2012, 00:24
  2. Astra G/Mk 4 Leather 3-Spoke Steering Wheel with Airbag
    Last Post: 11th April 2010, 20:58
