Results 1 to 10 of 27
Thread: 1.8vvt clutch
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    Default 1.8vvt clutch
    Sorry to bring this up again. I have the 1.8 vvt engine with clutch judder. I took it to my local Dealer (Lookers). To see if they could fault it, and guess what, they couldnt. So I rang customer services, and they have told my dealer to keep the car for 2 days, to see if they can fault it. While I was on the phone to them, I asked them, because there is a design fault on the clutch I have, why am I not entitled to a new clutch. The woman I was speaking to said "let me get you the manager" So I asked the manager the same question, and he denigd that there was a design fault, and said the reason VX have designd a new clutch is for "customer satisfaction"
    Aberdeen
    I have a simillar problem with my 06, 1.8veccy. Clutch is very jumpy between all of the gears, took it to the local dealer who investigated and they have admitied that the clutch is a bitt 'iffy' they even said it would be replaced under warrenty but they would have to order the parts. That was 4 weeks ago, I am still waiting for these parts to arrive!
    LOL... screen dump to your printer all the threads off here where folks have had their clutches changed, and ask him it it was because of a 'design fault' or customer satisfaction......wave them under his nose, and ask him to phone VX customer services and see if they won't make you a satisfied customer as well....
    Oct 2007
    Ellesmere Port
    This is the man at vauxhall customer services, that said this
    West Yorkshire
    Hi
    I have a 06 1.8 Sri with the clutch judder problem! I took it into vx last week and they diagnosed that it was juddering. They are replacing the clutch and the flywheel. (as mentioned in another post that the flywheel has to be changed too) It was in last wednesday and parts had to be ordered and the car is in this week to be sorted.
    The vx dealer said only one other car has had the problem and found out one after mine, so far only 3 have or going to have it sorted at my local delaer.
    I have the part numbers i think, but they are in my car which is at the dealers atm, once i get the car back and i will post them on here.
    hth
    Adrian
    Regular Member videodoctor's Avatar
    Blackpool
    Dave,i can pm you my case number when i had my clutch and flywheel changed.If other members did the same then Vauxhall wouldn't have a leg to stand on.
    I don't know why you having so much difficulty getting through to them.My dealer contacted Vauxhall and they approved the repair straight away.
    It is a known fault to Vauxhall and they are just fobbing you off.
    Let me know about the case number thing...might help.
    Regular Member skippyroo's Avatar
    chasing the sheep
    out of curiosity, is this a problem with all cars in the 1.8vvti bracket or just a specific year, ie, 06-56, and so on, i have an 07 and must admit i cant say i have felt anything, but best to err on the side of caution
    Blackpool
    It can affect all the facelift vvti 1.8 models.
    Mine is an 07 plate and had to have the clutch at 2000 miles.
    Keep your eye on the clutch.Mine only juddered when the car was warm and never first thing in the morning.I found that if i went to a big hill and slipped the clutch for a few seconds then it was smooth for a few days but would return and then get progressively worse.I took my car to the dealers at the end of the day so that it deffinately slipped and they rised a case number no problem.
    Oct 2007
    Ellesmere Port
    Thanks videodoctor, pm sent. I dropped my car in at my dealers this morning. Its going to be there for 2 days, to see if they can find the fault. I have been given a Corsa as a loan car, with a very guttless 1.0 3 cylinder engine
    West Yorkshire
    Hi
    Dave did they sort your clutch and flywheel out?
    I have got my car back today and the clutch is way better! APART from the fact that theres a dodgy noise coming from below the dash somewhere, but it is getting sorted tomorrow.
    Anyway i have got the part numbers.
    The clutch kit is 1x 93185663
    1x 55556349
    1x 24422061
    Flywheel is 1x 90536140
    All flywheel and clutchplate bolts 6x 90444148
    All subframe bolts
    1x 90092679
    3x 9200867
    6x 90295195
    2x 11103821
    2x 13122435
    2x 11102611
    2x 24456006
    HTH
    Adrian
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. 1.8vvt
    By platts007 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:24
  3. 1.8vvt
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2011, 11:48
  4. 1.8vvt clutch judder dealer problem
    By spartan80 in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2009, 19:29
  5. 25 mpg!!!!!! 1.8vvt sri
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2008, 07:45
cluch kit cost to replace a vauxhall vectra c 1.8 vvt
vectra c sri vvt 1.8 clutch kit
vectra c 1.8 vvt clutch
vectra 1.8 Vvt clutch
