Results 1 to 10 of 14
Thread: amp and sub...
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    Default amp and sub...
    I have a stupid noise coming through the sub and rear speakers that are connected to the amp. remember the noise a tape deck would make if the volume was low it would click click click, and same noise if you recorded onto a tape with nothing being recorded onto it.
    I have taken the wires out and then back in, the amp was replaced as the last one went into safe mode and wouldnt come back out of it.
    Its really annoying me now and I ripped all the wires out and started again and still dint work
    Redhill
    m8 you running good Quality power cable, straight from the battery, + Good Earth... thats normally the problem is a poor earth...
    Jul 2006
    mmmmmmmmmmmm
    Quote Originally Posted by Rockster View Post
    the earth goes to the earth for the rear lights, and the power cable is a fli power cable with a 30 amp fuse, but amplifier has to 25 amp fuse's in it. I have a fli 800 wat amp with 4 channels and a fli sub + vibe 6&9..
    any ideas?
    Redhill
    sound all good m8..... might be worth moving the earth off the same one as the lights.
    Jul 2006
    mmmmmmmmmmmm
    yea I moved it to seat belt bit, moved it to another bit and just kept on happening.. really F**ked me off
    member of the smoke patrol 230bhp+
    unplug the rca to make shore it is the amp first
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    run the power lead down one side of the car then the sound ones down the other side of the car. you could be gettin electric noise getting into the sound leads. one of my friends had a noise like this and thats what it was
    Jul 2006
    mmmmmmmmmmmm
    Quote Originally Posted by aerodynamic18 View Post
    This has been done, live and live remote down one side and rca leads down the other, ground in the boot. generally it makes a whirring noise if this is not done.
    RCA leads have been disconnected and then re-connected then the noise.
    Might it be that a negative wire is in a positive port?
    I have changed all the door speakers and one was very loose on passenger front, so I chopped off the plug and connected wire to wire, think I connected brown and yellow to red, and yellow to black. would that make a difference?
    Regular Member Ian's Avatar
    York
    how expensive are your RCA leads. I had the same issue in an older car, tried everything and in the end changed the RCA leads to a decent pair which stopped it. The fact that when you diconnected the RCA leads the noise went away hints alot that they are to blame.
    Quote Originally Posted by Ian View Post
    you will be looking at about £25 for a good set of rca leads
    streetwires are one of the best you can get
    if you go to a good car hifi shop they will help you out .
    when you do get the rca leads just run them over the seats to see if it all sorted if it is job done install them in the car
