Thread: Battery drain
    Oct 2006
    spalding
    Default Battery drain
    If the car is not used every day it won't start on the day you want it to. It is not a problem if used daily but one day off and it won't go the day after - does anyone have any ideas?
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    ask local garage to check battery.and check the ICE as this drained my battery.hth
    the battery that came with the car from new only lasts about the 3 year warranty period.. after that they seem to just suddenly die...get the battery tested for dead cells and get the alternator checked out for output and reverse drain ( in case the diode pack in the alternator has blow allowing the current to drain)..My hunch is on the battery failing TBH..
    Oct 2006
    spalding
    Auto Electrician Has Looked Car Over Today And Diagnosed The Wrong Size Battery Has Been Fitted, A ??? With 1 Number Being A 7? Should Be An 096, If That Means Anything To Anyone
    Jul 2006
    Means nothing to me, but at least you got it sorted
    Oct 2006
    spalding
    How Was The Golf Day Matey?
  1. Battery Drain
    By Alistair123 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 14:11
  2. Battery Drain
    By Gabonz1 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 22:16
  3. 19 amp battery drain
    By jimbobling in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 19:55
  4. CD 70 Battery Drain
    By davey9dollars in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2010, 22:05
  5. Battery Drain? any advice please
    By thewww2 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2006, 22:19
