Thread: fitting SRI Fogs
    North West
    Default fitting SRI Fogs
    been fitting FRIONT SRI BUMPER and SRI FOGS all is going well apart from the fact one of the holes on the foglight seems to be NOT in line with the hole on the bumper has anyone else had this is 1 of the fixings out of line.OR could i have been sold a pair of 2005-2007 foglights by mistake? IS there any difference between pre-facelift and the facelift foglights.
    Apart from that 1 hole out of line the fogs seem to fit perfect in the grill
    Dya think if i cable tie the out of line hole it would be enough support
    Regular Member shan's Avatar
    Hi mate. I know the fogs are different for pre and facelifted cars. The facelift 05/07 fogs are part no. LH 13170953 & RH 13170954 I carn't see the number's on the one's you have.
    Hopefully you have the correct one's be a bummer if they are the new one's.
    Somebody else maybe can confirm this issue.
    Regular Member ash_c64's Avatar
    May 2007
    London
    I have that same problem, my fogs dont line up but fit in the surround perfectly. The 2005-2007 fogs wont fit at all on this surround so these are not the facelift fogs. i Bought my fogs of ebay the box they came in had the right part numbers on them, but i couldnt match the part numbers on the actual fog lights. They fit and are secured so it doesnt really bother me. Can you get a front pics of the acutal fog, your fog looks different from mine.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Only issue I have is that my horn was in the way when I fitted my SRI fogs.
    North West
    the numbers on the fogs are
    13101745 R
    13101744 L
    On the box were different numbers LH 13170953 & RH 13170954
    Do Vauxhall sell the fixings for the foglights or are they just screws you use?
    I could probably make them fit,with a drillbit and some brackets n nuts but they should fit.
    ..........& when i fiited standard fogs i just loosened the horn and moved itr out of the way
    The box numbers are for the facelift one's. I'm not sure if the numbers on the units you have are for the pre-facelift. I presume they are. So i carnt understand why they dont fit.
    Are they from another VX and not for the Veccy? Somebody on here should now.
    North West
    im just gonna drill the 3rd hole in the bumper which i neeed to fix the fog unit its about 3/4 of an inch out
    May 2007
    London
    93175924 (LH) / 93175923 (RH) for pre-facelift, they dont match, maybe they came of another vauxhall car but not sure.
    North West
    i made them fit 2 nuts and bolts and a cable tie for the hole which was 3/4 inch out Done this for both
    they fit in the surround perfect so i will just keep them in now
    all brand new parts and didnt fit togetherits a good job i am handy with a drill
    thanx for ALL help!!!!! !!
  1. Help needed fitting H3 HID Fogs on to Facelift
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2012, 19:54
  2. Fitting front fogs
    By MadOnVaux! in forum Insignia car chat
    Last Post: 4th January 2012, 17:06
  3. fitting fogs
    By myelite150 in forum General Motoring Chat
    Last Post: 2nd December 2011, 19:19
  4. fitting my fogs
    Last Post: 9th September 2010, 15:01
  5. Fitting Fogs ??
    By gsxrster in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2007, 19:01
