Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Engine temp gauge not working ???
    Regular Member andythilo's Avatar
    Oct 2006
    Saffron Walden
    Default Engine temp gauge not working ???
    Past few days now it's been playing up.
    Basically when cruising, the needle doesnt move, i.e doesnt go up. If I cane it a bit then it may rise a little, but then drops back down to nothing.
    I also think the cabin heat has dropped, even after a long, if I put it on full heat, it's not that hot.
    Any ideas before I take it to the garage?.
    I've checked the water and oil and alls good.
    [Ex]Admin Duncan's Avatar
    Sounds like a dodgy thermostat.
    Oct 2006
    Saffron Walden
    Would that effect cabin heat though?
    Yup, if the thermostat is dodgy then it means the engine never gets to warm up properly, as indicated by the gauge, therefore there isn't sufficient heat to heat the cabin.
    Feb 2006
    Guttedsville
    Same troubles I had with mine early on. Definately Thermostat.
    Oct 2006
    Saffron Walden
    Ok thanks i'll get it booked in. TBH it's the only fault i've had and it's coming up for 30,000 miles and I had it from new last Nov. So cant be bad really.
    Sunny Dartmoor
    Quote Originally Posted by andythilo View Post
    Thats alot of miles.....
    In less than 12 months too....
    Wonder if you have the record for most miles travelled in a year...?????
    (on this forum anyway)
    May 2006
    scotland
    Yes agree, sounds like the thermostat. In 30 years of driving, I have only had 1 of these go unservicable on me and that was a real high miler car, but symptoms were exactly as you describe. It was stuck in the open position
    Oct 2006
    Saffron Walden
    Can't believe my local dealer. Told me it's normal for the diesel to run at 70 deg C.
    Phoned the other local dealer, taking it in there in Thu.
    Burton Brothers is the culprit for anyones future dealings, steer clear.
    They phoned me and asked if I could tell them what the other garage found lol, as I was steaming at the time I said NO, I've got better things to do.
    Bunch of *******
    Oct 2006
    Saffron Walden
    Quote Originally Posted by glenboy View Post
    Used to do nearer 45K a year .
    Do I get a prize?
  1. fuel and temp gauge not working
    By hovis007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 19:35
  2. Engine Temp Gauge not quite right
    By Di frost in forum Engine & Drivetrain
    Last Post: 30th December 2011, 12:52
  3. engine temp gauge
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 13:56
  4. Engine Temp gauge
    By cooky in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2009, 12:21
  5. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
vectra c temperature gauge problem
temperature gauge not working vauxhall vectra
vectra c engine temp not working
vauxhall vectra 56 temperature gage not working
vauxhall vectra c water temp not working
vauxhall vectra temperature gauge not working
vauxhall insignia 2010 temperature gauge fault
temperature gauge not working on vauxll victra
