Thread: Signum clutch?
    Oct 2007
    kent
    confused Signum clutch?
    I have manual 06 plate Signum 3.0CDTi and since remapping of electrics after 'limp home' incident operation of the clutch increases the revs when starting to depress pedal i.e. before disengaging to change gear and then the reverse happens once gear changed and the pedal is released i.e. revs drop just before last part of pedal travel! It's driving me nuts...especially as garage refuses to acknowledge fault! Only 10,500 miles and NetworkQ. Accelerator also very jerky when 'coasting' forwards at low speed in traffic.
    Anybody suffering with this or better solved similar problem?
    dudley
    Default Signum clutch?
    How long have you had the car? You are allowed to exchange within 30 days under Network Q. Mentioning this may hurry them up. Put in writing as well.
    Chris
    Regular Member shan's Avatar
    Ian C recently had the same issue with his veccy 3.0. He also thought it was the clutch. Had it into VX and they told him there is nothing at all wrong with it. I can not write what the issue was due to maybe VX looking at this site.
    Maybe PM him and he can confirm the exact issue's and solutions etc.
    Hope this helps you out mate.
    Also mate not to sure VX will be happy with a remaped warrented car. Have you told them you have done it?
    Maybe they will void the warranty?
    Somebody on here will confirm this.
    dudley
    My car is all original.
    I was telling peteh as he wrote he had an issue with his clutch.
    Am i missing something here.
    Are you also having the same issue with your standard car? I dont know if you dont tell.
    Oct 2007
    kent
    Vx dealer remapped (their terminology) electrics after car entered limp home mode. Car is otherwise original and regrettably outside Network Q 30 day exchange.
    you could still push them to take it back as the initail fault was within the 30 day period and they failed to fix it correctly..
    They didn't remap it, the correct term is 'updated' the software to he latest version..
    If it doesn't work sucessfully, i'd ask them to reinstall the software for your model year back onto the engines ECU..
  1. signum clutch problems
    By dave_3 in forum Engine & Drivetrain
    Last Post: 15th January 2011, 19:41
  2. Flywheel/clutch signum
    By HONESTJOE in forum Engine & Drivetrain
    Last Post: 7th March 2010, 17:17
  3. Signum clutch problem
    By HONESTJOE in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 15:40
  4. Signum Clutch - Can you Adjust?
    By Trundlebus in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 11:49
  5. Signum Clutch
    By david173 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2006, 22:51
