Thread: Interior Control Module
    Regular Member Darrell's Avatar
    Feb 2007
    Wolverhampton
    Default Interior Control Module
    Does anyone know
    a)What it is?
    b)What it controls exactly
    c)Where it is
    d)Where i might borrow a spare one for a quick trial?
    Thanks for any replies!
    Regular Member Ben H's Avatar
    Herts\Beds Border
    If it's like most control modules it will be coded to the specific car Vauxhall programmed it to.
    I was told when my engine control module was playing up if the garage had to replace it, when it gets programmed to my specific car and it doesn't fix the problem then tough, it's no longer any use to any other car so I'd have to pay for it as they can't just pick one off the shelf just for a tester.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    Quote Originally Posted by Ben H View Post
    If it's like most control modules it will be coded to the specific car VauxhallVauxhall programmed it to.
    Yep, I was looking into Cim Module in the steering shroud and it also needs to be tech 2'd to the car.
    Feb 2007
    Wolverhampton
    ok, with both your comments appreciated.
    The trouble i have is that none of them interior or courtesy (boot or glove box) lights are working, however, whenever i do try to turn them on, even though they dont work... it causes the heater panel to cut out. This includes turning on side lights.
    Again... However, if i fully dim the dash display with side lights on, the heater unit will come back to life and operate as normal. Which is weird, there must be a link between the whole lighting circuit as any light causes the heater panel to seemingly short out. Is it the control module that could be causing this problem??
    [Ex]Admin Duncan's Avatar
    OK, there are two modules that work on those parts.....
    Instrument Panel Electrical Centre (IPBEC) - installed in the left footwell, behind the A-pillar inner panelling. (i.e. behind the glovebox area). It contains relays and fuses.
    Body Control Module (BCM)
    - is the central control unit for the body electronics and is connected to the IPBEC.
    The BCM is programmed according to features present in the car, so needs to be reprogrammed if put into another car. The IPBEC doesn't appear to need programmed so looks like it's possible to test out one from another car. Battery needs to be disconnected before removing the modules.
    HTH
    Regular Member benny's Avatar
    Feb 2006
    dudley
    darrel do you have a none gen radio and amp fitted in the car ?
  1. Control Integrated Module (CIM)
    By robster23 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2011, 18:54
  2. Bodywork Control Module
    By Exclusive BV in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2011, 17:01
  3. Body control module ( bcm ) HELP
    By clive3373 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2009, 13:54
  4. Body Control Module
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2009, 17:50
  5. GSI Body Control Module?
    By 900ss in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 08:56
vectra c body control module location
vectra c body control module location www.vectra-c.com
body control module vectra c
opel vectra c body control modul www.vectra-c.com
vectra sat nav module
vauxhall vectra c body control module locations
www.vectra.modul.com
vauxhall vectra c interior light module
