Thread: Wheel Spacer's
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Default Wheel Spacer's
    I know this has been done before, so apologies for going over old ground.
    What are the negative effects of wheels spacer's, the new wheels i've bought look as tho' they're not gonna sit quite right in the arches(not arrived yet, just forward planning, they may be fine) so was gonna space them 5mm??(They have an offest of ET41)
    Now a few question's have sprung to mind...
    1) Are Wheel Spacer's in any way Dangerous?
    2) Will there be any noticeable difference in Tyre wear/Wheel Bearing wear?
    3) Do you need to use extended bolts with 5mm Spacer's?
    Has anyone on here used Wheel Spacer's before, and if so were they any good and did they achieve what you wanted them to achieve??
    These are the sort of thing i am looking at
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    They shouldn't be dangerous or a problem as long as they fit properly and the correct length bolts are used. A mate years ago had to use spacers on a BMW 3 series and he initially had problems as he was supplied the wrong spacers (wheel wobble and, worryingly, a couple of nuts kept coming loose until he realised).
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The only problem is none of them seem to have the centre boss (the bit that goes into the wheel) so you'll be relying on the bolts to centre the wheels if this isn't done right you'll get the wobbles!
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    ive used 5mm spacers on my old corsa b, never had any problems with them. with u only wantin to use 5mm spacers the wheel should still locate onto the hub usin the centre bore thingy.
    i personaly would get longer bolts if i could get them easily enough.
    Jun 2007
    Quote Originally Posted by tyreman View Post
    This was one of my biggest fears. Will measure the depth of the the Boss when the wheels eventually turn up and i change them.
    Jun 2006
    Somewhere...
    I remember now - that was the problem my mate had with the OZ wheels and the BMW, they tried shims but that didn't help so they eventually had some custom made to fit the spigot. never had a problem after that.
    It does, but not properly,the inside of the centre bore of most wheels is chamfered, add the spacer as well and thats the problem.Do you think Vauxhall put the boss there for fun?,the nuts only clamp the wheel and not centre it.
    thats y i wasnt 100% sure if the centre boss was long enough, cus of the chamfered inner edge.
    Regular Member Dave1.8's Avatar
    Oct 2007
    Ellesmere Port
    I have used 5mm spacers on my 1.8 Vec, and there was plenty of boss left to centre it, if thats any help
  1. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
  2. alloy wheel refurb. £20 per wheel, Birmingham
    By dannydm1 in forum Detailing and Car Care Discussion
    Last Post: 3rd September 2011, 18:42
