Results 1 to 10 of 11
Thread: MPG Confusion Solved!!
    Regular Member MattB's Avatar
    Jul 2006
    Harpenden
    Default MPG Confusion Solved!!
    I've been used to regularly acheiving mid-40's to the gallon in my previous SRi CDTi 150s. However, the trip computer in my new one was struggling to get above 38MPG since I took delivery.
    While I was concerned that there might be a problem, I didn't notice any difference in performance. The car also seemed to be easily acheiving well over 500 miles per tank, as I had enjoyed previously.
    Then I had a brain-wave and checked the settings on the CD70. It was set to US units and, of course, US gallons are different to UK gallons. Selecting UK units, I checked the trip computer to find the fuel consumption had jumped straight to 46MPG!
    Yep, it was me that set it to US units in the first place because I preferred distances in 'feet' on the sat nav rather than 'yards'.
    Mileage : 000
    I can not get mine to do 46 mpg whatever I do...................
    Regular Member danceade's Avatar
    Oct 2007
    stoke on trent
    Quote Originally Posted by ed taylor View Post
    Stop trying to reach take off speed lol
    Regular Member shan's Avatar
    Just shows how messed up our UK measument's are.
    Feet and inch's. Stone's and now kilo's. different gallons. What a mess.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Maybe its the yankies that have the gallons wrong rather than us
    Brighton
    Quote Originally Posted by deanos View Post
    Yep! There gallons are 16 Fluid Ounces, our Imperial Gallons are 20 Fluid Ounces.
    I also had the same issue, I was doing my fruit in realising the car was only averaging 28 MPG, until I changed the settings 25% increase straight away
    Incidentally as a matter of interest, does anybody know why they changed their measurements? I can only think that it was to bring it into line with Pounds and Ounces? Any ideas anyone
    Mileage : 000
    I thought it was 20 fluid ounces to our pint and 8 pints to our gallon.
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    ^Yeah, that's it: -
    • The U.S. fluid ounce is 1/128 of a U.S. gallon (3.785 litres)
    • The Imperial fluid ounce is 1/160 of an Imperial gallon (4.564 litres)
    1 US gallon = 0.8326 Imperial gallons
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Well, this inspired me to go check mine. I was content with the 39.2 mpg it was showing but thought it should be higher. Changed to UK units and am now reading 47 mpg! Delighted.
    Good thread.
    Now this is good reading. Still seams nobody is correct. We both keep makeing change's.
    Enjoy.
    1 U.S. fluid ounce = 1.041 British fluid ounces
    1 British fluid ounce = 0.961 U.S. fluid ounce
    1 U.S. gallon = 0.833 British Imperial gallon
    1 British Imperial gallon = 1.201 U.S. gallons
    Imperial units are the measurement units that were historically used in the British Commonwealth countries. They were very similar, but not identical, to the units that are still predominantly used in the United States.
    The Commonwealth countries have since switched to the SI system of units. Because references to the units of the old British customary imperial units are still found, the following discussion describes the differences between the U.S. and British customary systems.
    Differences between the U.S. and British Customary Systems
    Measures of length
    After 1959, the U.S. and the British inch were defined identically for scientific work and were identical in commercial usage (however, the U.S. retained the slightly different survey inch for specialized surveying purposes).
    Measures of volume
    The U.S. customary bushel and the U.S. gallon, and their subdivisions differ from the corresponding British Imperial units.
    Also, the British ton is 2240 pounds, whereas the ton generally used in the United States is the short ton of 2000 pounds.
    The American colonists adopted the English wine gallon of 231 cubic inches. The English of that period used this wine gallon and they also had another gallon, the ale gallon of 282 cubic inches. In 1824, the British abandoned these two gallons when they adopted the British Imperial gallon, which they defined as the volume of 10 pounds of water, at a temperature of 62°F, which, by calculation, is equivalent to 277.42 cubic inches. At the same time, they redefined the bushel as 8 gallons.
    [FONT=Arial, Arial, Helvetica]In the customary British system the units of dry measure are the same as those of liquid measure. In the United States these two are not the same, the gallon and its subdivisions are used in the measurement of liquids; the bushel, with its subdivisions, is used in the measurement of certain dry commodities. The U.S. gallon is divided into four liquid quarts and the U.S. bushel into 32 dry quarts.
    All the units of capacity or volume mentioned thus far are larger in the customary British system than in the U.S. system. But the British fluid ounce is smaller than the U.S. fluid ounce, because the British quart is divided into 40 fluid ounces whereas the U.S. quart is divided into 32 fluid ounces.
    From this we see that in the customary British system an avoirdupois ounce of water at 62°F has a volume of one fluid ounce, because 10 pounds is equivalent to 160 avoirdupois ounces, and 1 gallon is equivalent to 4 quarts, or 160 fluid ounces. This convenient relation does not exist in the U.S. system because a U.S. gallon of water at 62°F weighs about 8 1/3 pounds, or 133 1/3 avoirdupois ounces, and the U.S. gallon is equivalent to 4 x 32, or 128 fluid ounces.
    1 British Imperial gallon = 1.201 U.S. gallons [COLOR=#336699][B]
    More on imperial measurement units... Among other differences between the customary British and the United States measurement systems, we should note that they abolished the use of the troy pound in England January 6, 1879, they retained only the troy ounce and its subdivisions, whereas the troy pound is still legal in the United States, although it is not now greatly used.
    We can mention again the common use, for body weight, in England of the stone of 14 pounds, this being a unit now unused in the United States, although its influence was shown in the practice until World War II of selling flour by the barrel of 196 pounds (14 stone).
    In the apothecary system of liquid measure the British add a unit, the fluid scruple, equal to one third of a fluid drachm (spelled dram in the United States) between their minim and their fluid drachm.
    In Great Britain, the yard, the avoirdupois pound, the troy pound, and the apothecaries pound are identical with the units of the same names used in the United States. The tables of British linear measure, troy mass, and apothecaries mass are the same as the corresponding United States tables, except for the British spelling "drachm" in the table of apothecaries mass. The table of British avoirdupois mass is the same as the United States table up to 1 pound; above that point the table reads:
    14 pounds = 1 stone
    2 stones = 1 quarter = 28 pounds
    4 quarters = 1 hundredweight = 112 pounds
    20 hundredweight = 1 ton = 2240 pounds
    The present British gallon and bushel - known as the "Imperial gallon" and "Imperial bushel" - are, respectively, about 20 percent and 3 percent larger than the United States gallon and bushel. The Imperial gallon is defined as the volume of 10 avoirdupois pounds of water under specified conditions, and the Imperial bushel is defined as 8 Imperial gallons. Also, the subdivision of the Imperial gallon as presented in the table of British apothecaries fluid measure differs in two important respects from the corresponding United States subdivision, in that the Imperial gallon is divided into 160 fluid ounces (whereas the United States gallon is divided into 128 fluid ounces), and a "fluid scruple" is included.
    The full table of British measures of capacity (which are used alike for liquid and for dry commodities) is as follows:
    4 gills = 1 pint
    2 pints = 1 quart
    4 quarts = 1 gallon
    2 gallons = 1 peck
    8 gallons (4 pecks) = 1 bushel
    8 bushels = 1 quarter
    The full table of British apothecaries measure is as follows:
    20 minims = 1 fluid scruple
    3 fluid scruples = 1 fluid drachm = 60 minims
    8 fluid drachms = 1 fluid ounce
    20 fluid ounces = 1 pint
    8 pints = 1 gallon (160 fluid ounces)
  1. problem solved
    By wullierob81 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 18:51
  2. HID Flickering, solved?
    By Vizzeh in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2010, 20:33
  3. Rattle solved hopefully
    By satbeychap in forum Suspension, Wheels & Brakes
    Last Post: 10th August 2008, 15:32
  4. dilemma solved
    By spencer88 in forum General Chat
    Last Post: 5th September 2006, 02:44
