Thread: Ventilation/Climate Control Problem
    Belfast
    Default Ventilation/Climate Control Problem
    The centre "knob" which controls the menu select (ie up and down movement) on display screen seems to be faulty, in that whenb i get to the air distrubution/air conditioning select screen the rotational movment and push to select charateristic of the knob doesnt seem to function.
    When in the outermost mode (ie. front screen display) the rotational movment adjusts the airflow rate perfectly and the push/select takes me into the menu mode no problem!
    Anyone any idea what may be causing this???
    The "feel" of the knob (flame suit on for the sarcasm!!!) seems to be a little rougher than the heating controls on each side???
    Cheers in advance for any help.
    Al
    moved to the relevant section for you matey..
    The short answer is you need a new switch panel.. it connect to nothing apart from the cars wiring harness as the air control is all done with servo motors...
    It is a bit more "lumpy" on the centre control knob. Mine did this, but mine also would not control the air fan speed correctly. I had a new unit fitted in the end.
    Belfast
    any ideas how much this cost to replace? car is 6 mths out of warranty FFS!!!
    Oct 2006
    Wellingborough
    think he has ECC from the description. sounds like maybe a tech2 can fix it if the control for fan speed is working but not once your in distribution control.
    Sorry I have no idea, it was covered under the Net Q so I never saw a bill
    Belfast
    Quote Originally Posted by Flaninacupboard View Post
    Yes, i have the Climate Control Option so the fleabay options above wouldnt do. (but cheers anyway matey)
    Seems to be working fine again. Perhaps "reset" itself once ignition was switched off? would this be a likely fix??
    Mileage : 000
    It might has rest it,s self. People has mentioned that they has no "speedo dials" moving, but on switching the ignition off and on again they worked, keep an eye on it for a while it might be ok now, finger,s crossed.
  1. Climate control problem help!
    By CallumHill in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2012, 23:20
  2. Climate control problem
    Last Post: 11th December 2012, 23:58
  3. Climate control problem
    By POOL MAN in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2009, 09:00
  4. Another climate control problem
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2008, 21:08
  5. Climate Control problem
    By bnam in forum Electrical & ICE (including SatNav)
    Last Post: 17th July 2007, 14:09
