Thread: Preheating
    Regular Member badge25's Avatar
    Mar 2007
    west midlands
    Default Preheating
    This may be a stupid question but This is the first diesel I have had so I'm curious.
    Now that the cold weather is coming do I need to wait for the glowplug light to go out before starting the engine?? I haven't done it in the past but the light has only flicked on for a second but this morning it was on a little longer. The temp at 2.30am this morning was 2.5 degrees.
    spoons
    Guest
    Always a good idea to let the glow plug wake up the cylinders first on a cold and frosty morning..... and let them get ready for a kicking... rise and shine baby
    I always let mine go out before firing up
    Regular Member SignumPhil's Avatar
    Luton, Beds
    You should wait for the glowplug light to go out, but my 3.0 still starts if you don't, it just runs a bit lumpily.
    Or you could get up later!
    Phil
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    WAIT until the light goes out. It will aid starting and the engine will fire quicker, putting less wear on the rotating electrics. Also will put less strain on the engine after initial firing, as the engine will run smoother quicker.
    HTH
    Regular Member Karl's Avatar
    Sunderland
    always wait for the glow plug light to go out before starting
    Mar 2007
    west midlands
    Cheers for that guys. I thought it was advised but just thought i'd double check.
    Quote Originally Posted by SignumPhil View Post
    That would be the ideal situation but this week i start at 3.00 do one delivery to northampton pick a trailer up from coventry then go home so I ain't complaining.
    Regular Member ACE.TAG's Avatar
    Feb 2007
    hamilton
    Thats very interesting as i noticed that for the first time this morning as it was 1 degree up here when i was leaving the house at 5am!! Just to add to this someone also told me a while ago not to start my car and leave it running for 10 mins just to heat it up in the morning as it could do damage to it is this correct or alot of rubbish??
what temperature does the preheaters come on vectra c
