Results 1 to 10 of 16
Thread: Any building regs experts out there?
    Regular Member purple170503's Avatar
    kent
    Default Any building regs experts out there?
    I know it's not about cars but thought I'd ask. My neighbour has just built a new window into a ground floor wall which overlooks the front of our property. I am wondering if she needs to have had planning permission so wonder if there is any experts out there that could answer my query?
    Nicking Ya Dinner.
    I think so, across the road did this to open up the landing in his house, I must admit I wasn't consulted on it, but as he's a good bloke and it doesn't bother me I've never chased it up.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    your best bet would be to contact your local council to see if there is a plan for the works and they could tell you if your worried about your priversy
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Hi m8, I'm no expert, but have been looking in to an extension very soon, you need planning permission for 90% of work, and pretty much everything needs to conform to Building Reg,
    Sign yourself up to the planning Portal HERE it will give you a lot of advice, also go on to your local council web site, you'll be able to look over ALL planning permission requests for your road , you'll be able to check if they have asked for permission,
    Hope it helps a little
    Regular Member Ridgerider's Avatar
    Feb 2007
    If the wall is on the boundary, then they would not be allowed to insert a window into it as it would be a path for fire.
    If the wall is back from the boundary then you can have windows in walls (from a fire point of view) but it does open up the issue of overlooking.
    A few thoughts: -
    A window at ground floor level can always be responded to with some creative fencing solution on the boundary
    A window at first floor would probably trigger a planning application due to overlooking.
    Is your front garden overlooked from the street, or from other windows in the front of their house, in which case a window in a neighbouring property would probably not be regarded as an issue by the planners.
    Give the local planners a call and talk through your concerns with them.
    kent
    Cheers for the advice I'll drop my local council an e-mail I think
    Regular Member dezzie's Avatar
    May 2006
    blackpool
    Yes you do need a type of planning application/certificate as all installations have to be carried out by someone FENSA registered, so you have all the relevant paperwork should you sell the house. i am a window fitter but work for a local company and therefore are covered by their annual FENSA certificate. i would recommend you contact your local council to put your mind at rest though, hope this helps.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    the groundfloor extention on our property originally had a round window put into the side that was the boundry with the neighbours side-front garden.They objected and the window had to be filled in.So in your case i would of thought they would of needed planning permission,or at least you were given notice so that you could object....HTH
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I think you'll find it needs permision from the local building control dept.. It comes under parts L and M of the building regs and it would therefore be notifiable to the local councils building control dept and would need to be installed by a fensa registered installer or your neighbour would have to comply to certain things..
    Regular Member Karl's Avatar
    Sunderland
    Please be aware, if you don't really dislike your neighbour I wouldn't complain, things like this have a habit of creating MASSIVE neighbourly disputes.... (experience talking here)
  1. For Sale: O/S & N/S rear window regs to fit vec c
    By SRIDAN in forum Parts for sale
    Last Post: 9th September 2012, 19:01
  2. More regs
    By signum_rob in forum General Motoring Chat
    Last Post: 13th May 2012, 23:12
  3. Purchasing a house without Building Regs
    By the_wave_rider in forum General Chat
    Last Post: 21st March 2012, 09:55
  4. New MOT 2012 regs *worth a read*
    By andrew e in forum General Motoring Chat
    Last Post: 12th December 2011, 22:21
