Results 1 to 10 of 11
Thread: 1 ltr Oil added already !!
    Regular Member Silentknight's Avatar
    Swindon
    Default 1 ltr Oil added already !!
    Hi Guys,
    Please help, I had a service on my 2.2sri in April, since then I have had to add 1 litre of oil in 2 stages, this has now been used up and the oil light is on again.
    Is this normal ?
    Should I just get a oil and filter change done now?
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    Quote Originally Posted by Silentknight View Post
    Hi Guys,
    Is this normal ?
    I have had my 2.2 petrol for approx 23 months and to date I have never had to put in as much as a thimble full between services (PDI and my first one) I would get that amount of oil usage checked out asap. But then again how are you driving it and what mileage are you putting in?
    Nicking Ya Dinner.
    Sounds like you may have a leak somewhere, check behind the turbo the ring is a fav for letting oil past, diesel engines do consume oil by nature though, how many miles have you done in it so far?
    An oil and filter change will help anyway and you should do it, use VX 10/40 semi synth at the very least, it's not a hard job, the belly tray needs to come down, be careful to support it or it will flop and rip, and at £160 a go they ain't cheap, also the sump nut has a habit of being very hard to move, so get a good torx of the right size and a bar it it is stuck, make sure you replace the two rubber rings on the oil filter housing stalk. hth.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    VV - it may be a petrol 2.2
    It does sound like a leak to me - have you notced any pools or drips of oil on the driveway at all?
    Mine (although it is a 1.8) has had leaks from both the rear main oil seal and the sump plug recently, and I've had to put in similar amounts of oil.
    Nicking Ya Dinner.
    Quote Originally Posted by JuzzyD View Post
    Doh, yeah I think you might be right Juz.
    Regular Member Karl's Avatar
    Sunderland
    Now on my 3rd vectra and its the first not to use a litre per 1000 miles, my 2.0dti was horrendous, cost more in oil than petrol!
    Swindon
    Thanks guys for all your good advice.
    Mine is a petrol 2.2, i've had it now for about 1 and half years. last year I had to add 1 litre of oil between the 12 month service, now this year only 6 months have passed and like I said earlier it has already used the extra litre.
    There aren't any leaks on the drive at all. I do only travel a short distance to work each day and generally do short journeys, except for once or twice a week when I give it a good run.
    Im doing about 10 -12k miles per year
    Regular Member cameraman's Avatar
    Leicester
    I had a brand new 2003 2.2 elegance & it used a litre of oil every 3000 miles from new until I got the diesel when it had done 122000 miles, VX said it was OK
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Does sound a bit excessive mate. My 2.2 petrol doesn't use a drop now its fixed although it was once burning oil due to a broken oil scraper ring and also the head cracked which lead to oil being burned on zorst manifold. Due to it burning on manifold there was never any oil on road so it took a bit of finding. If your engine is clean including the head start by checking your coolant. Any smoke on start up?
    Swindon
    Eek
    I spoke to vauxhall about this last week. the guy at the service dept. said that if you read the manual, the section on oil consumption states that it can use 1 litre of oil per 1000 miles.
    WOW....
    However he also said that this is not true for all the vectras, but this is what could be consumed.
    At over £11 per litre I hope that my veccy doesn't get any thirstier..
  1. More Leather Added!!
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 27th May 2012, 12:02
  2. Added Value....!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 16:47
  3. few added bits
    By tat2006vectra in forum Quick Photo Album
    Last Post: 25th February 2008, 20:16
  4. Cleaned her and added a new mod!
    By VXR CDTi in forum General Chat
    Last Post: 17th February 2008, 12:11
