Thread: cd player
    Prescot
    Engine : 1.9 cdti
    Mileage : 130000
    Default cd player
    Hi All
    I have a vectra elite 04 plate did myself a cd disc from my computer put it in the car to play but it said error,so had a look at the audio manual and it said that it wont play cd r discs? my question is do the newer vectras play the cd rs and if so would i be able to put the cd player from one of them into mine or is there anything else i can do
    thanks for looking
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Hi mate. As said on similar threads, you can play home-made CDR's on the Vectra, just use good quality disks. I use Nero 6 to burn my disks and never had one fail on me in my 04 2.0T. I've got the CDR2005 radio/CD the car came with, and I assume you've got the CCR2006 in yours, so should be OK. Manual only says it may not play all CDR's to cover their ar$e. Sometimes people can have a problem if the CD's are burnt at too high a speed. HTH.
    Prescot
    Engine : 1.9 cdti
    Mileage : 130000
    thanks for quick reply ive got nero 7 what discs would you recommend?
    Oct 2006
    Waterloo, Liverpool
    10 Post(s)
    Trim : SRI NAV XP
    Mileage : 72K
    Any branded ones such as Sony, Philips, Verbatim, Maxell, or Mitsubishi, all of which I've used without problem, although I've used ones I've never heard of before OK. If your CD player plays pre-recorded CD's OK then it should play CDR's OK too.
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    i can play play cdr in my elite 54 has cd50 phone head unit.
    when i first tried to burn them and use them it was a bit tempermental, had to clean the disk before i put it in but now no problems, used both nero 6 and 7 and have used cheap cdrs from tesco....
  1. Cd player
    By tommythomson12 in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2011, 12:10
  2. Help with New Car DVD Player
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2011, 22:38
  3. MP3 Player
    By deanos in forum General items for sale
    Last Post: 14th November 2007, 21:28
